les.delancy Posted October 10, 2008 Share Posted October 10, 2008 Good grief! I've been gone a LONG time!!! I doubt if any of the people I was usually talking to are even on here any more. But... a year and a half in Iraq, a divorce, a new woman, and a new house in another state later _________ and here I am again. It alll started when I was going to buy a car for my daughter and we were going to build it together. I did research here and other places and decided what I wanted; a 1995 Del Sol VTEC - emerald green metallic. So, I found one in Utah and had a guy that worked with me go hook up the deal when he went home from Baghdad. It really is a beautiful all original car, very clean! Long story short - kid got in trouble and wouldn't listen so now the car is mine. I haven't started on it yet, but the new woman wants to go for it! We're going to build a street/drag car (there's a local strip close to the house here). Nothing crazy; staying N/A shooting around 300HP range. If I want to go suicidal I have a 300 SRT8. I have been loking around on the internet and here's what I've come up with: Skunk2 Honda parts: Pro-series intake manifold Pro-series throttle body Composite fuel rail -cylinder head Pro-3 camshaft Hi-Compression Valves Pro series titanium retainers Pro series valve springs Pro series cam gear Cam seal Hondata/Skunk2 ECU Mega Power exhaust system Pro-S coilovers Pro series plus adjustable front camber kit Lower control arms (rear) Lower arm bars (rear) Rear camber kit Strut tower bar Short throw shifter Billet shift knob Other needed items: Header Cold air intake Sway bars (?) -Brake mods Slotted and drilled rotors EBC red or yellow stuff pads Stainless steel brake hoses LSD for tranny -Fuel system Fuel injectors (550cc?) Pressure regulator Throttle cable Upgrade fuel filter (lines?) -Ignition system MSD pro-billet distributor / harness, module, and coil MSD Plug wires Plugs New high quality oxygen sensor -Cooling system Oil cooler Upgraded aluminum radiator Power Steering fluid cooler -Driveline LSD for tranny Flywheel Clutch Shifter stabilizer bushings Chromoly halfshafts Upgraded head studs Vibration dampner Under-drive pulley Magna-flow catalytic converter (or by-pass pipe?) I figure do all this and build a new short block after I blow the bottom end out of the stock one! I'm not real concerned with dress up stuff at this point. I'll want new wheels and tires just to fit bigger breaks and wider tires. I don want to go CF on the hood, taga top, and deck lid (all OEM style). I would love a CF OEM style rear spoiler, but all of the CF spoilers I have been able to find are not OEM style. Any comments, suggestion, questions, concerns? I can post pics of the car as is now if anybody's interested. Remember, this is just a general starting plan after one day of internet surfing! Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 Welcome back....I remember when you were looking for a car for your daughter. I've had a name change (formally HungGSR) so you might not recognize/remember me at all. As huge as your list is, that won't get you to 300whp. I'd say you should expect to spend a good 10 grand to hit that goal....maybe more. You'll want an SMSP, Hi-tech header, or something along those lines which will cost you well over a grand itself. You'll also need some high compression pistons, rods, maybe even a stroker setup. It sounds like you've done your research, but I hope you realize that if you were to go with boost, you could have 500-600whp for about the same amount as your 300whp n/a will be. Good luck with your build anyway. Link to comment Share on other sites More sharing options...
TS John Posted October 10, 2008 Share Posted October 10, 2008 I remember you too from back in the day, man. Hard to believe it's been a year and a half that I've been a regular on here... Best of luck with the build. It seems like you know way more than I do already, so I can't really contribute. My only request is pics and (eventually) a video... Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Author Share Posted October 10, 2008 I'll get pics of the car the way it is now during lunch. Maybe I should re-think and go turbo after all. Maybe a small T3 or similiar? I was thinking NA would sve me some oney, but maybe not! I suppose I could go with what I have now and just add the turbo (simple setup with an inter cooler and waste gate). I went too deep when I planned my first build, got into elec adjustable suspension and computer turbo controller. If I can stay calm and not go buck wild a simple turbo set up might be just what the doctor ordered. Hmm... Anybody know where to find an OEM style CF rear spoiler? Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 I'll get pics of the car the way it is now during lunch. Maybe I should re-think and go turbo after all. Maybe a small T3 or similiar? I was thinking NA would sve me some oney, but maybe not! I suppose I could go with what I have now and just add the turbo (simple setup with an inter cooler and waste gate). I went too deep when I planned my first build, got into elec adjustable suspension and computer turbo controller. If I can stay calm and not go buck wild a simple turbo set up might be just what the doctor ordered. Hmm... Anybody know where to find an OEM style CF rear spoiler? If 300whp is your goal regardless of power, you could get there with boost for about 3 grand. 400-500 for another 3-4 grand in a built engine (if you can do a lot the work). 280-300whp isn't all that hard with a stock B16, more than 300 you'd want to build the motor. Also if you go boost you'll want a bigger exhaust tubing. High hp N/A builds are really expensive......really expensive. Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Author Share Posted October 10, 2008 I'l definatley give it some deep thought! I will do all of the work myself (other that machining), that's all of the fun. I used to drag race years ago and built all of my own stuff (and fixed it when I got go-pedal happy!). I've just never done an import before. Thought it would be fun to try something new. You think all the listed items would still work with a T3 or similiar turbo? Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 I'l definatley give it some deep thought! I will do all of the work myself (other that machining), that's all of the fun. I used to drag race years ago and built all of my own stuff (and fixed it when I got go-pedal happy!). I've just never done an import before. Thought it would be fun to try something new. You think all the listed items would still work with a T3 or similiar turbo? T3 is a little small for high hp. T3/T04E is the common setup but if you want faster spool get a GT28rs or GT30rs (depending on your hp goals.) http://www.turbo-kits.com/del_sol_turbo_kits.html Second one down would be a good kit for ya I think. What are your goals on hp if you go with boost? Edit: Keep your eyes open on Honda-Tech and you can come across a used kit like above in really good condition for closer to 2 grand. Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Author Share Posted October 10, 2008 Thanks! I'm going to luch (I'll get pics). When I get back I'll do internet turbo research... Link to comment Share on other sites More sharing options...
CRG7 Posted October 10, 2008 Share Posted October 10, 2008 Welcome back! Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 Thanks! I'm going to luch (I'll get pics). When I get back I'll do internet turbo research... Found this for ya. About 1400 cheaper than a new kit and has the faster spooling GT28r turbo. http://www.hondamarketplace.com/zerothread/2349801 Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Author Share Posted October 10, 2008 Found this for ya. About 1400 cheaper than a new kit and has the faster spooling GT28r turbo. http://www.hondamarketplace.com/zerothread/2349801 Nice man! Thanks, that's awesome!!! Let's see if I can come up with the cash before someone else does... I got pics of the car the way it sits for you: I e-mailed themto myself and saved them on my computer, how do I attach them here? Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Author Share Posted October 10, 2008 Welcome back! Thanks! Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Author Share Posted October 10, 2008 Maybe I figured it out! Link to comment Share on other sites More sharing options...
CleanGSR Posted October 10, 2008 Share Posted October 10, 2008 Wow....that sucker is in awesome condition. I love the rare dark green colors on those....would look awesome with gold wheels (british racing style/look). The seats are awesome too,.....never seen them with the dark green stripe. Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Author Share Posted October 10, 2008 Yeah, I love the color... looked a long time for it! I was thinking black or dark grey wheels. I'm not going to paint the CF hood, tagra, trunk, and spoiler; so I figured a color close to the dark grey in the CF. I'm glad to hear someone else say it's in good shape, I was starting to convince myself I had paid entirely too much for it! Link to comment Share on other sites More sharing options...
wannaBstuntin Posted October 10, 2008 Share Posted October 10, 2008 Definitely nice shape. I like the color too. Black wheels would look good, but then again, I like black wheels on almost anything. Link to comment Share on other sites More sharing options...
Repsol Posted October 12, 2008 Share Posted October 12, 2008 .. That's immaculate. What I would do for a Del Sol already equipped with a five speed. Hell, even a B16. Link to comment Share on other sites More sharing options...
les.delancy Posted October 12, 2008 Author Share Posted October 12, 2008 Trust me, it was not easy to find one with both. Especially un-modified! And wanting only the one color didn't make it any easier... Link to comment Share on other sites More sharing options...
Repsol Posted October 12, 2008 Share Posted October 12, 2008 Yeh. I'd love to have one just for a day. Well, maybe a lot longer, a day would be a tease. Link to comment Share on other sites More sharing options...
les.delancy Posted October 12, 2008 Author Share Posted October 12, 2008 Wanna rent it for a week before I tear into the engin? LOL! Link to comment Share on other sites More sharing options...
Repsol Posted October 12, 2008 Share Posted October 12, 2008 I thought you'd never ask. Link to comment Share on other sites More sharing options...
madmax82 Posted October 12, 2008 Share Posted October 12, 2008 Nice Find Link to comment Share on other sites More sharing options...
delsolranger Posted October 13, 2008 Share Posted October 13, 2008 Nice. Before you tear in to it, maybe you should just sell it to me. Does the world really need another modded out sol? Link to comment Share on other sites More sharing options...
Orca89 Posted October 13, 2008 Share Posted October 13, 2008 Nice. Before you tear in to it, maybe you should just sell it to me. Does the world really need another modded out sol? Actually, what the world needs is people to rescue the Sol's that've been mutilated by people with no respect for them. Link to comment Share on other sites More sharing options...
les.delancy Posted October 13, 2008 Author Share Posted October 13, 2008 Ok, first one with $10,000 wins! Speaking of how pretty it is... now the bad (maybe someone can help). The console lid is broken and the buttons up on the dash above the steering wheel are faded all to hell (hazard flasher, cruise ect...). Any body have suggestions where to get a OEM interior replacement parts? The dealers I have tried say that can't get them anymore. I will have to replace the whole console box to fix the lid. Link to comment Share on other sites More sharing options...
