jkm345 Posted October 7, 2008 Share Posted October 7, 2008 i recently put my engine back together, but now its leaking and i dont know where or HOW???i see it coming from the block (the part where the head and bottom block meet)..its like leaking from that point right on top of where the transmission connects to the engine, under the vtec-solenoid. Its wet there..i wipe it off, drove it and nows its wet again, it doesnt leak when the engine is turn on, but wen it is, it starts to leak..its not a heavy leak though..I just want to noe if anyone can help me out, or have this problem before with advice. I tighten the bolts that connect the head to the block 2lbs more then the recommended torque, is it NOT tight enough or wat?? Link to comment Share on other sites More sharing options...
88prelude Posted October 7, 2008 Share Posted October 7, 2008 i recently put my engine back together, but now its leaking and i dont know where or HOW???i see it coming from the block (the part where the head and bottom block meet)..its like leaking from that point right on top of where the transmission connects to the engine, under the vtec-solenoid. Its wet there..i wipe it off, drove it and nows its wet again, it doesnt leak when the engine is turn on, but wen it is, it starts to leak..its not a heavy leak though..I just want to noe if anyone can help me out, or have this problem before with advice. I tighten the bolts that connect the head to the block 2lbs more then the recommended torque, is it NOT tight enough or wat?? you could try that or you might have to take the head apart and replace the head gasket because it might have been a bad one Link to comment Share on other sites More sharing options...
jkm345 Posted October 9, 2008 Author Share Posted October 9, 2008 im pretty sure its not the head gasket...i bought a new one and this isnt the first time that it happened to me!! Link to comment Share on other sites More sharing options...
cmgogo Posted October 9, 2008 Share Posted October 9, 2008 im assuming its leaking coolant. Well the wonderful thing about coolant is that its UV reactive. clean the crap outa your engine bay, get a VERY powerfull black light, and track that bad boy down. Link to comment Share on other sites More sharing options...
88prelude Posted October 9, 2008 Share Posted October 9, 2008 i recently put my engine back together, but now its leaking and i dont know where or HOW???i see it coming from the block (the part where the head and bottom block meet)..its like leaking from that point right on top of where the transmission connects to the engine, under the vtec-solenoid. Its wet there..i wipe it off, drove it and nows its wet again, it doesnt leak when the engine is turn on, but wen it is, it starts to leak..its not a heavy leak though..I just want to noe if anyone can help me out, or have this problem before with advice. I tighten the bolts that connect the head to the block 2lbs more then the recommended torque, is it NOT tight enough or wat?? you never mentioned it was coolant :thumbup: Link to comment Share on other sites More sharing options...
jkm345 Posted October 11, 2008 Author Share Posted October 11, 2008 yeahs, its coolant..the things is that, there is not much room to be looking around at it!!but i did happen to tighten the head down a lil more, and it somewhat stop the leaking a bit less! Link to comment Share on other sites More sharing options...
mpearce1974 Posted October 11, 2008 Share Posted October 11, 2008 yeahs, its coolant..the things is that, there is not much room to be looking around at it!!but i did happen to tighten the head down a lil more, and it somewhat stop the leaking a bit less! You do know you were supposed to re-torque head after so many miles, right? Link to comment Share on other sites More sharing options...
lastresort576 Posted October 11, 2008 Share Posted October 11, 2008 new or old head studs? Link to comment Share on other sites More sharing options...
mpearce1974 Posted October 11, 2008 Share Posted October 11, 2008 new or old head studs? Good point! Link to comment Share on other sites More sharing options...
jkm345 Posted October 12, 2008 Author Share Posted October 12, 2008 wells i just used the old head studs...was i suppose to get new ones??i mean, i didnt do anything to it, just switch out the bottom block...could that be the prob>? Link to comment Share on other sites More sharing options...
Kastigir Posted October 12, 2008 Share Posted October 12, 2008 wells i just used the old head studs...was i suppose to get new ones??i mean, i didnt do anything to it, just switch out the bottom block...could that be the prob>? If they're bolts and not actual studs, they need to be replaced when removed. The bolts used are torque to yield bolts. Link to comment Share on other sites More sharing options...
