Hondahunter Posted October 5, 2008 Share Posted October 5, 2008 When it's cold, my motor searches for idle for a good five minutes. When I bought it, I had a CEL and ran the code. It turned out to be a TDC sensor, so I replaced the whole distributor and fixed the light. Unfortunately, the idle was only slightly improved. It idles fine when it's a warm day or after it's warmed up. Any ideas? Link to comment Share on other sites More sharing options...
mpearce1974 Posted October 5, 2008 Share Posted October 5, 2008 When it's cold, my motor searches for idle for a good five minutes. When I bought it, I had a CEL and ran the code. It turned out to be a TDC sensor, so I replaced the whole distributor and fixed the light. Unfortunately, the idle was only slightly improved. It idles fine when it's a warm day or after it's warmed up. Any ideas? Only drive when it 75 or warmer? Link to comment Share on other sites More sharing options...
Hondahunter Posted October 5, 2008 Author Share Posted October 5, 2008 Only drive when it 75 or warmer? That's the redneck way to fix problems!!! lol. That could be an option, IF this weren't my DD. Link to comment Share on other sites More sharing options...
DelSolSweetie Posted October 5, 2008 Share Posted October 5, 2008 move to FL? haha but okay yah umm.. tune up? Link to comment Share on other sites More sharing options...
Hondahunter Posted October 6, 2008 Author Share Posted October 6, 2008 move to FL? haha but okay yah umm.. tune up? Has new plugs, wires, Mobil1 full syn, distrib, battery, starter and adjusted the valves...any other things to do? Lol Link to comment Share on other sites More sharing options...
DelSolSweetie Posted October 6, 2008 Share Posted October 6, 2008 check your timing maybe Link to comment Share on other sites More sharing options...
Hondahunter Posted October 6, 2008 Author Share Posted October 6, 2008 check your timing maybe Forgot to mention that...Done Link to comment Share on other sites More sharing options...
DelSolSweetie Posted October 6, 2008 Share Posted October 6, 2008 buy a new car haha put some fuel injector cleaner in it? im just naming random stuff now haha Link to comment Share on other sites More sharing options...
Hondahunter Posted October 7, 2008 Author Share Posted October 7, 2008 buy a new car haha put some fuel injector cleaner in it? im just naming random stuff now haha remind me NOT to trust you in the future! haha jk! I might throw some cleaner in, I did it 10k ago, but I ran unleaded in it so probably wouldn't hurt to clean her up again. Link to comment Share on other sites More sharing options...
the_big_dl86 Posted October 7, 2008 Share Posted October 7, 2008 do u have an idle air control valve?some b16s have it and others dont.this could easily be ur problem.also check all vacuum lines.before i did my swap my car did that crap.but my new manifold had no spot for that valve so i didnt use it.also i removed the majority of vacuum lines for emissions crap and it stopped.also timing coulkd have something to do with it. Link to comment Share on other sites More sharing options...
tallhamer88 Posted October 7, 2008 Share Posted October 7, 2008 Only drive when it 75 or warmer? its a summer car:). Link to comment Share on other sites More sharing options...
Hondahunter Posted October 7, 2008 Author Share Posted October 7, 2008 its a summer car:). haha this is true It would be super nice if I had something to drive the rest of the time. But then again it would have to be something else with a B-series :sorcerer: Did I mention I LOVE new emoticons?!?!?! Link to comment Share on other sites More sharing options...
Hondahunter Posted October 7, 2008 Author Share Posted October 7, 2008 do u have an idle air control valve?some b16s have it and others dont.this could easily be ur problem.also check all vacuum lines.before i did my swap my car did that crap.but my new manifold had no spot for that valve so i didnt use it.also i removed the majority of vacuum lines for emissions crap and it stopped.also timing coulkd have something to do with it. I almost missed you post! Hmm, idk I'll have to check my service manual to see if I have one or not. Timing has already been set, I did that when I replaced my distributor. Link to comment Share on other sites More sharing options...
Hondahunter Posted October 7, 2008 Author Share Posted October 7, 2008 I do have an idle air control valve. I don't have a CEL on though? Link to comment Share on other sites More sharing options...
les.delancy Posted October 10, 2008 Share Posted October 10, 2008 poor idle air flow will not always activate CEL - check for vaccum leaks and air leaks in your intake system - if that's not it remove TB and IAC motor and clean all ot the passages really well with TB cleaner - make sure you are very careful with the TB gasket or use a new one Link to comment Share on other sites More sharing options...
Hondahunter Posted October 17, 2008 Author Share Posted October 17, 2008 poor idle air flow will not always activate CEL - check for vaccum leaks and air leaks in your intake system - if that's not it remove TB and IAC motor and clean all ot the passages really well with TB cleaner - make sure you are very careful with the TB gasket or use a new one I'm gonna do that soon, I'm almost sure that's gonna be my problem. I'll letcha know! Link to comment Share on other sites More sharing options...
