Ronco85 Posted September 29, 2008 Share Posted September 29, 2008 Yeah I've recently bought my 98 Civic EX with and aftermarket 2" exhaust with a high flow catilytic converter. My CHECK ENGINE LIGHT is on because of no O2 sensor after the cat. If I were to just buy a new O2 sensor after the converter, would that take care of the ENGINE LIGHT?? Or will I need to buy a new sensor AND converter?? Link to comment Share on other sites More sharing options...
CleanGSR Posted September 29, 2008 Share Posted September 29, 2008 Yeah I've recently bought my 98 Civic EX with and aftermarket 2" exhaust with a high flow catilytic converter. My CHECK ENGINE LIGHT is on because of no O2 sensor after the cat. If I were to just buy a new O2 sensor after the converter, would that take care of the ENGINE LIGHT?? Or will I need to buy a new sensor AND converter?? It depends on if your car has an actual high flow cat such as magnaflow, catco, or random technologies or if it has the so-called high flow cat from ebay that is in reality a resonated straight pipe. If it has a true high flow catalytic converter then you should be fine assuming it's in good condition. If it's the ebay type then you'll need to get an actual cat. Link to comment Share on other sites More sharing options...
Ronco85 Posted September 29, 2008 Author Share Posted September 29, 2008 It depends on if your car has an actual high flow cat such as magnaflow, catco, or random technologies or if it has the so-called high flow cat from ebay that is in reality a resonated straight pipe. If it has a true high flow catalytic converter then you should be fine assuming it's in good condition. If it's the ebay type then you'll need to get an actual cat. Yeah it's pretty much just a straight pipe, thanx Link to comment Share on other sites More sharing options...
