jerrodh Posted September 29, 2008 Share Posted September 29, 2008 97 Ranger with the 2.3l 4cylinder. Just did a plugs/wires and filter change as well as an oil change. I've done a little research and the only thing I could think of is either the wires are in the wrong firing order (not plugged into the cap in the right place apparently) which would be an easy fix but how do I know the order? Or the point game of the plugs is not set but I'd rather not do this untill unless someone else thinks that is the problem and there isn't easier things to check first? As is the truck starts/runs fine just a knocking/clicking noise constant at idle and all though not as loud is still heard when driving. Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 29, 2008 Share Posted September 29, 2008 97 Ranger with the 2.3l 4cylinder. Just did a plugs/wires and filter change as well as an oil change. I've done a little research and the only thing I could think of is either the wires are in the wrong firing order (not plugged into the cap in the right place apparently) which would be an easy fix but how do I know the order? Or the point game of the plugs is not set but I'd rather not do this untill unless someone else thinks that is the problem and there isn't easier things to check first? As is the truck starts/runs fine just a knocking/clicking noise constant at idle and all though not as loud is still heard when driving. Google firing order! Had to do it myself on my MAzda! Link to comment Share on other sites More sharing options...
jerrodh Posted September 29, 2008 Author Share Posted September 29, 2008 Thanks found that so I'll check that tomorrow morning. Least it runs so I can take it to autozone or something see if they got any ideas but f*ck I'm broke. Link to comment Share on other sites More sharing options...
