88prelude Posted September 19, 2008 Share Posted September 19, 2008 okay anyway... i was driving earlier today all normal like and i turn into my neighborhood and all the sudden when i give my car gas it boggs down like plugs arent firing and when i went to the beach today it wouldnt start for like 2 hours ( this is an 88 prelude carb. 5 speed) so i had a friend of mine bring me to autozone to have the external coil tested but they said it was fine.. i put the coil back in and turned the car over for like a minute straight and it finallly started but its still bogging down but the higher the RPM's the more gas i can give it and it wont bogg down...i had the whole distributor replaced under 10000 miles ago and its got all new wires and 4-tipped plugs so... SOMEONE PLZ HELP!!! i was told the 2 parts (the names of them are misplaced in my mind atm.) inside the distributor could have gone bad but i really dont wanna mess with them and they are freakin expensive i was told it could also be the fuel pump... but idk...btw im not stupid when it comes to cars so you can use big words with me any help/suggestions are much appreciated Link to comment Share on other sites More sharing options...
Kastigir Posted September 19, 2008 Share Posted September 19, 2008 Ditch the +4 plugs. Run standard coppers or platinums if you must. Pull the plugs, check their condition. Do this and report back. If they're truly fouled, you're either running rich, or burning way too much oil. Link to comment Share on other sites More sharing options...
James Matteu Posted September 19, 2008 Share Posted September 19, 2008 Spark: Do what he said^^ Fuel: You're right about the fuel pump but don't forget about the emissions system as well: get your ear down on the intake manifold and listen for vaccum leaks, you should be able to hear a faint hissing if you have a leak. Link to comment Share on other sites More sharing options...
88prelude Posted September 19, 2008 Author Share Posted September 19, 2008 well i am running rich..very rich and idkl why i doi have my cat removed but i doubt that has anything to do with it and are those plugs really that bad? and suggestions on what kind/brand of plugs to buy? and how would i know for sure if the plugs are really shhot completely? and im not burning any oil...but there is some black smoke out my exhaust when i start the car but other than that it runs clean Link to comment Share on other sites More sharing options...
James Matteu Posted September 19, 2008 Share Posted September 19, 2008 Others may have better suggestions, I only ever use NGK. Link to comment Share on other sites More sharing options...
cmgogo Posted September 19, 2008 Share Posted September 19, 2008 NGK ftw. as far as running rich check your float valve, it may need to be adjusted. Link to comment Share on other sites More sharing options...
88prelude Posted September 19, 2008 Author Share Posted September 19, 2008 okay so ngk it is Link to comment Share on other sites More sharing options...
Kastigir Posted September 19, 2008 Share Posted September 19, 2008 NGK BPR6ES or something like that. Don't remember exactly. If you can't get NGKs, then Densos will work as well. As for your fouled plugs, it is a 20 year old car, have you done a compression test to see if you're blowing by the rings? This would cause an oil burn, and fouling of plugs. Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 19, 2008 Share Posted September 19, 2008 Others may have better suggestions, I only ever use NGK. Only plug that belongs in a Honda! Link to comment Share on other sites More sharing options...
88prelude Posted September 20, 2008 Author Share Posted September 20, 2008 well im not burning any oil...and the crappy quad tipped plugs were the problem i went up to autozone and got some NGK standards for 2 bucks a peice car runs awesome...i was gonna get the NGK iridium plugs but they were outta stock Link to comment Share on other sites More sharing options...
88prelude Posted September 20, 2008 Author Share Posted September 20, 2008 NGK ftw. as far as running rich check your float valve, it may need to be adjusted. what and where is the float valve and i also have another question...whenever i downshift my cars exhaust pops ...what could that be caused by...someone said i need to adjust the air flow to the carbs Link to comment Share on other sites More sharing options...
cmgogo Posted September 20, 2008 Share Posted September 20, 2008 what and where is the float valve and i also have another question...whenever i downshift my cars exhaust pops ...what could that be caused by...someone said i need to adjust the air flow to the carbs Read and Read some more Link to comment Share on other sites More sharing options...
Kastigir Posted September 21, 2008 Share Posted September 21, 2008 what and where is the float valve and i also have another question...whenever i downshift my cars exhaust pops ...what could that be caused by...someone said i need to adjust the air flow to the carbs Sounds like a backfire. Unburnt fuel in the exhaust. Not having a cat will do that. You can eliminate it by getting that carb tuned right, or putting the cat back on. Link to comment Share on other sites More sharing options...
88prelude Posted September 22, 2008 Author Share Posted September 22, 2008 Sounds like a backfire. Unburnt fuel in the exhaust. Not having a cat will do that. You can eliminate it by getting that carb tuned right, or putting the cat back on. it is backfires....but it did it before i had my cat removed Link to comment Share on other sites More sharing options...
Hondahunter Posted October 3, 2008 Share Posted October 3, 2008 it is backfires....but it did it before i had my cat removed Is the car loud on a regular basis?? Maybe the muffler is burnt out? Or is it even the stock muffler? Link to comment Share on other sites More sharing options...
88prelude Posted October 3, 2008 Author Share Posted October 3, 2008 my car is very loud because i have the cat removed and the muffler is a 1 in dual out silverline resonated muffler here is the link to the muffler i have on my car it is the 4th one down on the list http://www.silverlineexhaust.com/Silverlin...lers/index.html Link to comment Share on other sites More sharing options...
tallhamer88 Posted October 3, 2008 Share Posted October 3, 2008 Only plug that belongs in a Honda! AMEN BROTHER! Link to comment Share on other sites More sharing options...
CleanGSR Posted October 3, 2008 Share Posted October 3, 2008 I'm amazed it hasn't been said yet, but running without a cat will cause you to run rich and in some cases (coupled with other mods) very rich. Do everybody a favor and put a cat back on. It will sound better, probably help or fix your problem and won't kill all the baby whales and sea lions. And to my knowledge, the NGK's and Denso's are pretty much identical, but yeah, NGK's would be my first choice. Link to comment Share on other sites More sharing options...
Hondahunter Posted October 4, 2008 Share Posted October 4, 2008 my car is very loud because i have the cat removed and the muffler is a 1 in dual out silverline resonated muffler here is the link to the muffler i have on my car it is the 4th one down on the list http://www.silverlineexhaust.com/Silverlin...lers/index.html I would guess the backfire is due to the cat/muffler combo. Most performance mufflers will backfire on motors this small, and many times on pushrod V8s also Link to comment Share on other sites More sharing options...
88prelude Posted October 5, 2008 Author Share Posted October 5, 2008 well i was told by a few different people/mechanics that my carbs need to be adjusted forr the backfiring to stop Link to comment Share on other sites More sharing options...
88prelude Posted October 5, 2008 Author Share Posted October 5, 2008 I'm amazed it hasn't been said yet, but running without a cat will cause you to run rich and in some cases (coupled with other mods) very rich. Do everybody a favor and put a cat back on. It will sound better, probably help or fix your problem and won't kill all the baby whales and sea lions. And to my knowledge, the NGK's and Denso's are pretty much identical, but yeah, NGK's would be my first choice. it sounds alot better without the cat...i get alot more ricer sound outta the car and i noticed an increace in power without the cat Link to comment Share on other sites More sharing options...
mpearce1974 Posted October 5, 2008 Share Posted October 5, 2008 well i was told by a few different people/mechanics that my carbs need to be adjusted forr the backfiring to stop You do know that all motors need a certain amount of back pressure to function and run properly? Link to comment Share on other sites More sharing options...
88prelude Posted October 5, 2008 Author Share Posted October 5, 2008 You do know that all motors need a certain amount of back pressure to function and run properly? i was told by the mechanic that cut my cat out that since i have a pipe running all the way back to a resonated muffler will not harm the motor and i have enough back pressure Link to comment Share on other sites More sharing options...
mpearce1974 Posted October 5, 2008 Share Posted October 5, 2008 i was told by the mechanic that cut my cat out that since i have a pipe running all the way back to a resonated muffler will not harm the motor and i have enough back pressure You has stock piping still as well? Stock diameter? Link to comment Share on other sites More sharing options...
88prelude Posted October 5, 2008 Author Share Posted October 5, 2008 You has stock piping still as well? Stock diameter? nope...2" all the way back...or 2 1/4 or 2 1/2 idr im pretty sure its 2" from the flex pipe i still get stock headers cause its impossible to find them for the base carbbed model Link to comment Share on other sites More sharing options...
