V-tak Posted September 5, 2008 Share Posted September 5, 2008 okay so i'm thinking about swapping the engine in my 92 cx with a k20 but i'm worried about whether the transmission will be able to handle it, does anyone have any suggestions or thoughts on what i should do? Link to comment Share on other sites More sharing options...
SNooPYjdm Posted September 5, 2008 Share Posted September 5, 2008 your worried if what tranny will be able to handle what?? Link to comment Share on other sites More sharing options...
cmgogo Posted September 5, 2008 Share Posted September 5, 2008 that trans wont bolt up to your stock motor, you need the trans that comes with the motor. Link to comment Share on other sites More sharing options...
V-tak Posted September 5, 2008 Author Share Posted September 5, 2008 your worried if what tranny will be able to handle what?? well it's a nearly new engine fitted to a 16 year old tranny, i'm just worried that with the extra power that the k20 would bring that the tranny might be more likely to fail, that combined with the fact that i'm pretty new to the whole swapping thing, i'm just wondering if i need to replace the trans. and if i do need to then what should i replace it with? Link to comment Share on other sites More sharing options...
SNooPYjdm Posted September 5, 2008 Share Posted September 5, 2008 well it's a nearly new engine fitted to a 16 year old tranny, i'm just worried that with the extra power that the k20 would bring that the tranny might be more likely to fail, that combined with the fact that i'm pretty new to the whole swapping thing, i'm just wondering if i need to replace the trans. and if i do need to then what should i replace it with? dude u need the k series tranny with the motor you cant use the tranny currently in your cx Link to comment Share on other sites More sharing options...
V-tak Posted September 5, 2008 Author Share Posted September 5, 2008 that trans wont bolt up to your stock motor, you need the trans that comes with the motor. okay, thanks, i'm new to this whole thing, didn't think it'd be that easy, i guess now i just need to find a trans. for a k20 Link to comment Share on other sites More sharing options...
SNooPYjdm Posted September 5, 2008 Share Posted September 5, 2008 yea u need the k series trans to bolt up with the k20 but thats a pretty complicated swap never done one myself but heard it was alot of extra work but its well worth it Link to comment Share on other sites More sharing options...
alex37211 Posted September 5, 2008 Share Posted September 5, 2008 First time swap......you don't know that K won't interchange with D.....I'm not trying to be a dik, but you sound like you're getting ahead of yourself here. Search and read and read and search. Get all over google. Read for at least 3-6 months before you decide which swap to go with. If you want to jump into one sooner, get a B-series. And no....your old cx trans won't bolt up to a B-motor either. A "swap" consists of motor, tranny, ecu, wiring harness, and shift linkage (also mounts are muy importante). Easiest swap for you (gain of approx. 32 hp or roughly 30% in your case)....D16Z6. You can actually use your old trans w/ this one, but I wouldn't (the gearing is longer in yours). This is a really cheap option too. You want K? $4-$5k+. Get the d16z6...500-800 bucks. Get a b20....$800-$1200. Give or take. Get a b18c1 swap and completely double you HP...like $1500-$2200 avg. (I bought a wrecked GSR teg for $900 ) . Hope this helps put things into perspective a little for you. Link to comment Share on other sites More sharing options...
..SSR.. Posted September 5, 2008 Share Posted September 5, 2008 Fab an adaptor plate and flywheel and let me know how you like 6 reverses and 1 foward gear. Link to comment Share on other sites More sharing options...
