Jergen2 Posted August 29, 2008 Share Posted August 29, 2008 91 Accord LX 4 cylinder automatic. Issue: No spark. History: Did a full tune up 2 days ago after finding oil in all of the spark plug holes that had kept it from starting (including replacing the valve cover and spark plug hole gaskets). Did not replace the coil. Vehicle started right up after replacing these things, was not driven, very next day absolutely no spark. Link to comment Share on other sites More sharing options...
Turtlehead Posted September 1, 2008 Share Posted September 1, 2008 91 Accord LX 4 cylinder automatic. Issue: No spark. History: Did a full tune up 2 days ago after finding oil in all of the spark plug holes that had kept it from starting (including replacing the valve cover and spark plug hole gaskets). Did not replace the coil. Vehicle started right up after replacing these things, was not driven, very next day absolutely no spark. Could be a multitude of things. Here is a list of what I would be initially suspecious of. 1. The PGM-FI main relay 2. The ignitor (located internally within the distributor sub-assembly) 3. The coil packet (which should be located externally since you have and LX) 4. Possibly the electrical portion of the ignition switch Typically oil in the spark plug tubes will not cause the car to not run, but the above can cause no spark issues. Link to comment Share on other sites More sharing options...
