accordspeed97 Posted May 10, 2002 Share Posted May 10, 2002 Someone HELP!!.......I have a '97 Accord LX. My SRS light came on and won't go away because I disconnected the SRS sensor under the steering wheel when I was putting my gauges in. Little did I know that you were supposed to disconnect the battery ahead of time so that this wouldn't happen. Well now I'm stuck with this light on all the time and it's getting pretty fu*king annoying.......My question is does anybody know how to reset the ECU in my car so that the light will go away? If you do please let me know.....i'm begging you!!..........Thanks for your time!!! Link to comment Share on other sites More sharing options...
theotherachiever Posted May 11, 2002 Share Posted May 11, 2002 try disconnecting the negative end on the battery and leavin it for like 10 minutes ??? then connect it again. if that doesnt work ull probably have to take it to the dealership and have them turn it off for you Link to comment Share on other sites More sharing options...
