CelticRacer Posted April 15, 2008 Share Posted April 15, 2008 I need to remove the passenger interior door panel on my 94 del sol. i was wondering if anyone has any experience doing this and could give any words of wisdom etc... thanks in advance Link to comment Share on other sites More sharing options...
airjordan223 Posted April 15, 2008 Share Posted April 15, 2008 yeah its pretty easy. theres a small screw where the door handle is. once you remove this, just slide the handle out. another one below it on the handle that you pull the door closed with (theres a round tab you pull out to get to it, and need a long screw driver for this). and then theres another one on the top left sort of where the door meets the fender. the rest are just tabs. Link to comment Share on other sites More sharing options...
CelticRacer Posted April 15, 2008 Author Share Posted April 15, 2008 yeah its pretty easy. theres a small screw where the door handle is. once you remove this, just slide the handle out. another one below it on the handle that you pull the door closed with (theres a round tab you pull out to get to it, and need a long screw driver for this). and then theres another one on the top left sort of where the door meets the fender. the rest are just tabs. thanks alot. i am having an issue with the window. it wont move and i am trying to see whats wrong. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 15, 2008 Share Posted April 15, 2008 which window? make sure that toggle switch isnt on Link to comment Share on other sites More sharing options...
CelticRacer Posted April 15, 2008 Author Share Posted April 15, 2008 which window? make sure that toggle switch isnt on passenger window, toggle switch is not on. i believe it is the actuator. do you know of anything else that could be causing the problem? Link to comment Share on other sites More sharing options...
alex37211 Posted April 16, 2008 Share Posted April 16, 2008 Once you get the regulator exposed, use a jumper pack with screw drivers or run a long wire from your car battery and one from a ground; Take the plug out from the window motor and power it directly to see if it works. Use extreme caution not to touch the wires together. This will be a very close quarters operation. Switching the wires around will change the direction of the window (up or down). If the window moves with direct power, it may be either your switch or possibly a fuse. I'm not sure if each regulator has its own fuse but I think it does. If your fuses are all good and your switch isn't the problem... then you've got a problem...a wiring problem. And those are a biatch to isolate. good luck Link to comment Share on other sites More sharing options...
CelticRacer Posted April 16, 2008 Author Share Posted April 16, 2008 Once you get the regulator exposed, use a jumper pack with screw drivers or run a long wire from your car battery and one from a ground; Take the plug out from the window motor and power it directly to see if it works. Use extreme caution not to touch the wires together. This will be a very close quarters operation. Switching the wires around will change the direction of the window (up or down). If the window moves with direct power, it may be either your switch or possibly a fuse. I'm not sure if each regulator has its own fuse but I think it does. If your fuses are all good and your switch isn't the problem... then you've got a problem...a wiring problem. And those are a biatch to isolate.good luck thanks, i didnt even think it could have been a fuse... Link to comment Share on other sites More sharing options...
CelticRacer Posted April 24, 2008 Author Share Posted April 24, 2008 does anyone have a fuse daigram for the 94 sol? i havent been able to find one... Link to comment Share on other sites More sharing options...
CelticRacer Posted April 24, 2008 Author Share Posted April 24, 2008 its alive!!!! my passenger window is fixed! the idiot i bought it from put a 7.5 amp fuse in a 20 amp slot. so it was blown. now i just have to get a new fuse and i am set. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 25, 2008 Share Posted April 25, 2008 its alive!!!! my passenger window is fixed! the idiot i bought it from put a 7.5 amp fuse in a 20 amp slot. so it was blown. now i just have to get a new fuse and i am set. wow some people are smart. glad you didnt have to replace anything big Link to comment Share on other sites More sharing options...
CelticRacer Posted April 25, 2008 Author Share Posted April 25, 2008 wow some people are smart. glad you didnt have to replace anything big yeah me too, thanks for the help. Link to comment Share on other sites More sharing options...
