black06g85 Posted March 8, 2008 Share Posted March 8, 2008 Ok I'm helping a co-worker out with his car. Just installed a new engine from a CRX. Car cranks, Car has spark, Has fuel pressure, but no injectors. We've already replaced the main relay on the car, opened up the stock ecu to find that it was burnt up and a resistor was blown. Replaced the ECU with an AEM unit, flashed the correct calibration, and still doing the same thing. There is no exhaust on the car yet, just an open flange coming out of the turbo and there is no fuel smell even after trying to start it for 5-10 minutes. We've gone through all of the wiring, fuses, relays, and still the same. I'm stuck so any help would be greatly appreciated. Thanks in advance for your help. Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted March 8, 2008 Share Posted March 8, 2008 the only thing i can think of is the injectors might be clogged or maybe need some adjustment Quote Link to comment Share on other sites More sharing options...
black06g85 Posted March 8, 2008 Author Share Posted March 8, 2008 the only thing i can think of is the injectors might be clogged or maybe need some adjustment that is a possiblility since the injectors sat out of the car for about 2-3months, but I've never had all 4 go in a car in the 12 years I've been working on em. They don't fire at all though, there is no fuel going into the motor. Just to check, I sprayed some starting fluid in there, and it fired right up, so I'm pretty sure the timing is correct and it is definitely getting spark. Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted March 8, 2008 Share Posted March 8, 2008 does it have gas ? lol did you prime it ? Quote Link to comment Share on other sites More sharing options...
black06g85 Posted March 8, 2008 Author Share Posted March 8, 2008 does it have gas ? lol did you prime it ? Lol of course man. and yeah it holds 40psi at the rail when cranking. Quote Link to comment Share on other sites More sharing options...
MiekyG Posted March 8, 2008 Share Posted March 8, 2008 crank it over a few times, pull the spark plugs and see if they are wet from fuel, then wile the sparkplugs are out have youre buddy crank it over a few times and you should see puffs of gas poppin up out the cyclinder when the piston hits TDC (top dead center) and from there you will find out if you are getting fuel, after you find out about that then you can worry about whats next~!~ Quote Link to comment Share on other sites More sharing options...
black06g85 Posted March 8, 2008 Author Share Posted March 8, 2008 crank it over a few times, pull the spark plugs and see if they are wet from fuel, then wile the sparkplugs are out have youre buddy crank it over a few times and you should see puffs of gas poppin up out the cyclinder when the piston hits TDC (top dead center) and from there you will find out if you are getting fuel, after you find out about that then you can worry about whats next~!~ tried that too man, nada... plugs are dry Quote Link to comment Share on other sites More sharing options...
black06g85 Posted March 16, 2008 Author Share Posted March 16, 2008 tried that too man, nada... plugs are dry update, found the problem and car is up and running.... was usuing the wrong distributor. Quote Link to comment Share on other sites More sharing options...
delsol209 Posted March 17, 2008 Share Posted March 17, 2008 wow something simple that you just overlook sometimes good job bro Quote Link to comment Share on other sites More sharing options...
black06g85 Posted March 17, 2008 Author Share Posted March 17, 2008 wow something simple that you just overlook sometimes good job bro yeah isn't that the way it always turns out. Can't wait to get the rest of the IC piping run and start tuning this thing. Quote Link to comment Share on other sites More sharing options...
