James Matteu Posted March 7, 2008 Share Posted March 7, 2008 As much as I would like to build one like this myself, I wouldn't mind just taking the keys off his hands. No crazy intercooler visible from the outside, no crazy body kits, no crazy paint colors, just clean. 1/4 mi time: 12.005 at 92.87 ENGINE -JE 9:1 PISTONS -EAGLE RODS (ARP 2000 BOLTS) -AEBS INTAKE MANIFOLD (POLISHED) -STR 65MM THROTTLE BODY -RC 750CC PEAK & HOLD INJECTORS -AEM FUEL RAIL -AEROMOTIVE 1TO 1 FUEL PRESSURE REGULATOR -WALBRO 255 LPH FUEL PUMP -GM 3 BAR MAP SENSOR -REVHARD STAGE II TURBO W/CUSTOM COLD AIR INTAKE W/K&N FILTER -CLEVITTE MAIN & ROD BEARINGS -NUFORMZ BLOCK GUARD (TAC WELDED & DECKED @ MESA BALANCING) -COMETIC .040" HEAD GASKET -TODA BILLET OIL PUMP GEARS(84MM) -FIDANZA ADJ. CAM GEARS -CROWER STAGE II TURBO CAMS -REV SPRINGS & TITANIUM RETAINERS -REV 1MM OVERSIZED EX VALVES .5MM OVERSIZED INTAKE VALVES -NEW VALVE SEALS & GUIDES -PORT & POLISH PERFORMED @ EXTREME CYLINDER HEADS (PALM CITY) -3" THERMAL RACING DEVELOPMENT CAT BACK EXHAUST (STAINLESS) -ACT STREETLITE CHROMOLY FLYWHEEL -SPEC STAGE II PRESSURE PLATE & STAGE III DISC -DRIVESHAFT SHOP STAGE II AXLES -MUGEN 176 DEG. THERMOSTAT & FAN SWITCH -NEW FUEL FILTER -B & M FUEL PRESSURE GUAGE -NEXGEAR THERMAL BARRIER INTAKE MANIFOLD GASKET -OBD0 B16A ENGINE -NEW T-BELT,WATERPUMP& ALL NEW SEALS -TURBO XS BOOST CONTROLLER (20 PSI) -NO LIFT SHIFT & LAUNCH CONTROL -NEPTUNE RTP ENGINE MANAGEMENT (LIVE TUNING & DATALOG) -EXHAUST MANIFOLD & DOWNPIPE CERAMIC COATED -MSD SPARK PLUG WIRES & NEW OEM WIRES -FLUIDYNE RADIATOR -FAL COOLING FAN -NEW IDLE CONTROL MOTOR -ARP HEAD STUDS -ARP MAIN STUDS -NGK 8'S SPARK PLUGS -CUSTOM 3" DOWNPIPE CHASSIS -INTEGRA BRAKES IN FRONT W/ NEW INTEGRA MASTER CYLINDER & CALIPERS -POWERSLOT ROTORS ALL AROUND -RUSSELL STAINLESS BRAIDED BRAKE LINES ALL AROUND -HAWK BRAKE PADS ALL AROUND -ENERGY SUSPENSION MASTER BUSHING SET (RED) -TOKICO STRUTS ALL AROUND(BLUE) -GROUND CONTROL COIL IVERS ALL AROUND -DARKSTAR RACING TRACTION BARS -HASPORT MOUNTS & SHIFT LINKAGE -FLAMING RIVER- BATTERY/ALTERNATOR CUT OFF SWITCH -NEW SUNROOF PANEL (OEM) -DC SPORTS BATTERY TIE DOWN W/ 3/8" BOLTS -WHEELS LOCKS -205/50-14 BFG DRAG RADIALS Link to comment Share on other sites More sharing options...
chris_agu28 Posted March 7, 2008 Share Posted March 7, 2008 SEXY!!! I would take the keys off his hands anyday. That is a total sleeper. It likes like it is brand new off the lot. Makes me wanna buy one and build it like this. But it would be nowhere as clean as this. Where did you find it? Link to comment Share on other sites More sharing options...
James Matteu Posted March 7, 2008 Author Share Posted March 7, 2008 Where did you find it? AUTOTRADER!! LOL Link to comment Share on other sites More sharing options...
HONDA CRX 88 SI Posted March 7, 2008 Share Posted March 7, 2008 nice and clean thats what i like to c were performence and oem style meet. Link to comment Share on other sites More sharing options...
Nancy Posted March 7, 2008 Share Posted March 7, 2008 thats like the ultimate sleeper car right there. nice and clean, looks brand new. Link to comment Share on other sites More sharing options...
Tubbith Posted March 7, 2008 Share Posted March 7, 2008 so this is pretty much exactly what i want to do.. cept with a b18...it might be the nicest crx i have ever seen.. Link to comment Share on other sites More sharing options...
Ben. Posted March 7, 2008 Share Posted March 7, 2008 Wait wait wait wait.. 12 seconds at less than 100mph? SOMEONE'S bullcrapting about their times.. Link to comment Share on other sites More sharing options...
Tubbith Posted March 7, 2008 Share Posted March 7, 2008 Wait wait wait wait.. 12 seconds at less than 100mph? SOMEONE'S bullcrapting about their times.. I was thinking the same thing.. Link to comment Share on other sites More sharing options...
Ben. Posted March 7, 2008 Share Posted March 7, 2008 I was thinking the same thing.. I've seen Mustang's and Camaro's trap mid 13's at less than 100 mph. Never seen one break into the 12's at less than 100; or any other car for that matter. And they can launch great. Link to comment Share on other sites More sharing options...
James Matteu Posted March 7, 2008 Author Share Posted March 7, 2008 He scanned his slips from the track and posted them on his myspace. But anything is possible (photoshop, etc.), so I just take the information with a grain of salt. Who is petty enough to photoshop a time-slip from the track, on the other hand, he is trying to sell the car. Link to comment Share on other sites More sharing options...
Ben. Posted March 7, 2008 Share Posted March 7, 2008 He scanned his slips from the track and posted them on his myspace. But anything is possible (photoshop, etc.), so I just take the information with a grain of salt. Who is petty enough to photoshop a time-slip from the track, on the other hand, he is trying to sell the car. I'm just saying.. I haven't seen a car come out of the 13's at less than 100mph.. Fastest I've seen at under 100 was a MazdaSpeed6 running 13.5@99.2mph. Second was a '04 Mustang GT running 13.6@98mph with a 1.9 60' amazingly enough. Link to comment Share on other sites More sharing options...
Kegger Posted March 7, 2008 Share Posted March 7, 2008 Huge amount of power in a 2000 lb car. It's believable-ish. Link to comment Share on other sites More sharing options...
Ben. Posted March 7, 2008 Share Posted March 7, 2008 No, not really. A vehicle can only move so far, so fast, at such a certain rate of speed. Link to comment Share on other sites More sharing options...
the_big_dl86 Posted March 8, 2008 Share Posted March 8, 2008 ya trap speed is def off.and with as much mods as that rex has it should run faster then 12s neway.unless the boost is way down and i doubt that with all the awesome internals on it.he should be pushing 15-20 lbs for sure.maybe he just needs the driver mod! or he gets no traction Link to comment Share on other sites More sharing options...
Ben. Posted March 8, 2008 Share Posted March 8, 2008 Spinning the tires will increase trap speed in the quarter mile. He's obviously getting traction. The time slip is obviously fracked. Link to comment Share on other sites More sharing options...
the_big_dl86 Posted March 8, 2008 Share Posted March 8, 2008 ya must be lol Link to comment Share on other sites More sharing options...
