honda will not crank over engine
heavyevy
:crazy: 1993 10th anniversity accord
Battery, terminals are fine; large 80 amp breaker under hood check out; 12volts to all three connectors at solenoid;
jumpered small wire terminal on solenoid to positive terminal of battery nothing happen; when ignition switch turn on
no clicking sounds from starter area.
Sounds like the solenoid has gone bad. You can get a replacement one at like autozone. It might have voltage but if you jumped it and nothing happened then you might wanna look at getting a new solenoid.
If you can, remove the starter and take it to autozone or advance to get it tested. They could tell you if the starter has gone bad and if so which part.
