RamAirDave Posted March 3, 2008 Share Posted March 3, 2008 So I got a CEL yesterday, had the following codes.. 0108 manifold absolute pressure/barometric pressure circuit high input and 1129 Map Sensor Value More Than Expected. It made the car not want to idle..and die..also hard to start. Put in the new Map Sensor yesterday, seemed fine. today on the way home..same thing..wont idle..so when I come to a stop it wants to die, and runs rough..then CEL light back on. What do you think the issue is ?? Any help is appreciated. Dave Link to comment Share on other sites More sharing options...
dcletten Posted March 4, 2008 Share Posted March 4, 2008 id say check your wiring for the map sensor, make sure nothings cut or shorting out anywhere Link to comment Share on other sites More sharing options...
