studentmechanic Posted February 29, 2008 Share Posted February 29, 2008 I have a 95 civic that I just got in. I know nothing about it but the oil is milky and overfilled so im pretty confident their is a good amount of water in it. I took a compression test and it had 150 psi all across. I did a running compression test and they all had 90 psi. The exhaust does seem to puff out some smoke or at least steam. I did a combustion leak test on the coolant to see if their was any exhaust in the coolant and it didnt really seem like their was. So now I am pretty confused! Thanks, Matt. Quote Link to comment Share on other sites More sharing options...
Tubbith Posted February 29, 2008 Share Posted February 29, 2008 I say replace the oil and check it then. Also, you could nee piston rings. they would casue you to smoke... more so upon acceleration, but smoke none the less.. Quote Link to comment Share on other sites More sharing options...
dcletten Posted February 29, 2008 Share Posted February 29, 2008 intake mani leak? TB leak? Quote Link to comment Share on other sites More sharing options...
Kegger Posted February 29, 2008 Share Posted February 29, 2008 (edited) Headgasket's gone. Milky oil and white exhaust are indicative. As well as the low compression. Edited February 29, 2008 by Kegger Quote Link to comment Share on other sites More sharing options...
pistol_P Posted March 1, 2008 Share Posted March 1, 2008 if your engines revin up n down over heating then yes. but try changing the oil first and drive it for a good 2-3 miles or till the motor runs hot then check if the fluids still look the same. Quote Link to comment Share on other sites More sharing options...
chris_agu28 Posted March 1, 2008 Share Posted March 1, 2008 Headgasket's gone. Milky oil and white exhaust are indicative. As well as the low compression. 1+ Trust me I know about replacing head gaskets, It is simple but very time consuming and suck doing. Trust me. While you have the head off, Check to make sure the head is alright as well. I worked on a car to relace a head gasket only to come to find out that the head has a crack in it. Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted March 1, 2008 Share Posted March 1, 2008 I have a 95 civic that I just got in. I know nothing about it but the oil is milky and overfilled so im pretty confident their is a good amount of water in it. I took a compression test and it had 150 psi all across. I did a running compression test and they all had 90 psi. The exhaust does seem to puff out some smoke or at least steam. I did a combustion leak test on the coolant to see if their was any exhaust in the coolant and it didnt really seem like their was. So now I am pretty confused! Thanks, Matt. did you use the block tester which you use a special liquid in the tool and put it in the coolant opening of the radiator. If there is exhaust going through your gasket the lquid will change color. Is it that one you did? You can also fill it up with water and with the cap off, remove one spark plug at a time and put compressed air in the cylinder, check for bubbles Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted March 1, 2008 Share Posted March 1, 2008 you got a bad head gasket mang. fix that sh*t lol Quote Link to comment Share on other sites More sharing options...
