pistol_P Posted March 1, 2008 Share Posted March 1, 2008 have someone try starting it up and you tap on the distributor and if that doesnt work replace the fuel pump relay under the drivers side kick panel. not the one under the hood. if theres spark from the plug wires then im pretty sure thats the problem. Link to comment Share on other sites More sharing options...
rocknskulls Posted March 1, 2008 Share Posted March 1, 2008 i would check your fuel filter before you call a mechanic Link to comment Share on other sites More sharing options...
Kastigir Posted March 1, 2008 Share Posted March 1, 2008 It is entirely possible to get a bad relay. How to check: Open your hood. Remove the banjo bolt in the fuel filter. Either yourself, or someone else turn on the ignition and see if you get fuel. If fuel, then relay is fine. If no fuel, have person inside the vehicle lightly tap the fuel relay. If you then get fuel you have a bad relay. I bought a new one for my CRX, and I still wasn't getting any fuel. A few taps later...voila! Fuel. Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 1, 2008 Author Share Posted March 1, 2008 It is entirely possible to get a bad relay. How to check: Open your hood. Remove the banjo bolt in the fuel filter. Either yourself, or someone else turn on the ignition and see if you get fuel. If fuel, then relay is fine. If no fuel, have person inside the vehicle lightly tap the fuel relay. If you then get fuel you have a bad relay. I bought a new one for my CRX, and I still wasn't getting any fuel. A few taps later...voila! Fuel. i took the bolt off from the filter and i got no fuel. i already changed the relay. Link to comment Share on other sites More sharing options...
Kastigir Posted March 1, 2008 Share Posted March 1, 2008 i took the bolt off from the filter and i got no fuel.i already changed the relay. Did you try tapping the relay lightly? Pull it and have it tested. You probably got a bad relay. If the relay is good then your fuel lines are clogged, or your fuel pump is shot. Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 1, 2008 Author Share Posted March 1, 2008 Did you try tapping the relay lightly? Pull it and have it tested. You probably got a bad relay. If the relay is good then your fuel lines are clogged, or your fuel pump is shot. what do u mean by shot fuel pump??? Link to comment Share on other sites More sharing options...
Hatch92 Posted March 1, 2008 Share Posted March 1, 2008 ^ bad fuel pump Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 1, 2008 Author Share Posted March 1, 2008 ^ bad fuel pump i just replaced the pump and the relay Link to comment Share on other sites More sharing options...
Kastigir Posted March 1, 2008 Share Posted March 1, 2008 Then you have a bad relay, or clogged fuel lines. Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 2, 2008 Author Share Posted March 2, 2008 Then you have a bad relay, or clogged fuel lines. how many times is the relay supposed to click??? mine only clicks twice. Link to comment Share on other sites More sharing options...
lceah Posted March 2, 2008 Share Posted March 2, 2008 it's supposed to click 3 times...yours is not clicking the 3rd time! usually with problems, the 3rd is the one missing! so there you go!! Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 2, 2008 Author Share Posted March 2, 2008 it's supposed to click 3 times...yours is not clicking the 3rd time! usually with problems, the 3rd is the one missing! so there you go!! i checked on my friends 95 integra, and yeah his clicks 3 times. mine only clicks twice. good thing i got lifetime warranty, ill just go get another one. Link to comment Share on other sites More sharing options...
Kastigir Posted March 2, 2008 Share Posted March 2, 2008 i checked on my friends 95 integra, and yeah his clicks 3 times. mine only clicks twice.good thing i got lifetime warranty, ill just go get another one. Hell of a deal right there. No Honda dealer I've ever been to has given me a lifetime warranty. Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 2, 2008 Author Share Posted March 2, 2008 Hell of a deal right there. No Honda dealer I've ever been to has given me a lifetime warranty. Its from oreileys Link to comment Share on other sites More sharing options...
Kastigir Posted March 2, 2008 Share Posted March 2, 2008 Its from oreileys Therein lies your problem. It's most likely a remanufactured relay, and not a new one. Link to comment Share on other sites More sharing options...
speedfreek09 Posted March 2, 2008 Share Posted March 2, 2008 sounds to me like a clogged fuel filter more than anything replace it EVERYTIME when you change fuel pumps and the sock in the tank also Link to comment Share on other sites More sharing options...
lceah Posted March 3, 2008 Share Posted March 3, 2008 so what happened? Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 5, 2008 Author Share Posted March 5, 2008 so what happened? i still cant find the problem, i changed fuel pump, fuel filter, main relay, and other fuses. Link to comment Share on other sites More sharing options...
lceah Posted March 6, 2008 Share Posted March 6, 2008 since this happens when the engine is hot, could it be vapor lock? this is pretty rare but we have gone through many possibilities... Link to comment Share on other sites More sharing options...
chris_agu28 Posted March 6, 2008 Share Posted March 6, 2008 So you have spark and the fuel is flowing right? hhmmm I dunno about this. You might have got a bad pump as well. you got a lifetime warrenty on that too? Link to comment Share on other sites More sharing options...
97blackonblackcivic. Posted March 12, 2008 Author Share Posted March 12, 2008 PROBLEM SOLVED!!!!!! it turned out to be an electrical problem!!! Link to comment Share on other sites More sharing options...
