notaricer Posted February 24, 2008 Share Posted February 24, 2008 i have a 1996 honda prelude 5 speed S. i just got a job and want to start upgrading it. i thought that a cold air intake would be a good start, and ive seen that "short ram"s are alot cheaper than a full cold air intake. whats the difference and which should i get? also what are some other good ideas for upgrading? thanks Quote Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 24, 2008 Share Posted February 24, 2008 (edited) A big difference will be is where you live. Like it would be hard to have a cold air intake on a Daily Driver where I live is cause I rains and If I hit a puddle with that kinda setup then the water will get in the engine and water lock it. So short ram is for me. The cold air intake is longer and near the ground where all the cold air is flowing when you are driving. Hence the name. A short ram is good if you short on space. One disadvantage is that when the air flows through filter is kinda warm from the engine heat mixing with the cold air. I think Cold air intakes are good to have but like me it would be hard so I stick with Short ram. If you are unsure then just get a short ram and play it safe. Anybody wanna add on? Edited February 24, 2008 by chris_agu28 Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted February 24, 2008 Share Posted February 24, 2008 get a cold air intake. its very hard to hydrolock your motor, you would have to have the filter submerged into a puddle/lake. ive had one on my sol for 4 years and been through some pretty bad rain storms and have had no problems. but if you really are that worried you can also get a bypass valve for it which will absorb any water/moisture that might get up into the tube. Quote Link to comment Share on other sites More sharing options...
notaricer Posted February 25, 2008 Author Share Posted February 25, 2008 i live in spokane washington. it rains some but snows ALOT during winter. will snow screw it up? what are the performance advantages of a cold air vs a short ram? and how hard are these to install? Quote Link to comment Share on other sites More sharing options...
