speed demon Posted February 24, 2008 Share Posted February 24, 2008 ok, so im rebuilding my 89 crx 1.5HF.im pretty much starting from scratch though because the car has alot of rust and the engine is on its way out. any good ideas on good parts at cheap prices. also, should i put another 1.5 in it or convert to another engine? any help would be appreaciated. Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 24, 2008 Share Posted February 24, 2008 getting a new engine is all based upon your budget and what you can afford. Same goes for rebuilding it but it will be ALOT cheaper to rebuild it. I would drop a new motor in. But yet that is what I would do. Link to comment Share on other sites More sharing options...
James Matteu Posted February 25, 2008 Share Posted February 25, 2008 Restore that car. The DX is the trim you need if you want to swap, HF is not cost effective. The real value lies in restoring the car until you get the original mpg with only a minor patina. Link to comment Share on other sites More sharing options...
