zcef9 Posted February 24, 2008 Share Posted February 24, 2008 ok first off how would i change a bad rod barring? Link to comment Share on other sites More sharing options...
Tubbith Posted February 24, 2008 Share Posted February 24, 2008 If you have to ask, its probably not something you want to attempt. Your gonna need rod, bearing, and probably a crank... Link to comment Share on other sites More sharing options...
zcef9 Posted February 24, 2008 Author Share Posted February 24, 2008 well i know the crank is good and i got another rod and piston to reaplace the old one i just want to know would i have to take my motor out to replace it? Link to comment Share on other sites More sharing options...
injen78 Posted February 24, 2008 Share Posted February 24, 2008 id recommend taking it out..also you cant just replace one rod bearing...you will need to replace all of them,,and then that means you will need to replace the rod bolts,you will need to rehone the cylinder walls and then get new rings,because its not good to use old rings Link to comment Share on other sites More sharing options...
zcef9 Posted February 24, 2008 Author Share Posted February 24, 2008 dang how much do you think that would cost if i took them to a shop insted of doing this my self Link to comment Share on other sites More sharing options...
Tubbith Posted February 24, 2008 Share Posted February 24, 2008 its not gonna be cheap... what motor do you have? mightt be cheaper/easier to replace the block...unless of course you are trying to build... Link to comment Share on other sites More sharing options...
zcef9 Posted February 24, 2008 Author Share Posted February 24, 2008 its a d16a6 Link to comment Share on other sites More sharing options...
..SSR.. Posted February 24, 2008 Share Posted February 24, 2008 If a bearing is bad, the crank is bad. You'll need a crank, a rod, and a bearing. Since the rod will be used you'll need to have it resized when installing new rod bolts. Since you're buying new rods bolts, you should do all the rods. Since you're having to pull the engine apart, you'll need at the minimum to have it honed and put new rings in it. Bored + oversized pistons would be better to freshen it up. See cheaper to buy a good used block than fix your problem for more info. Link to comment Share on other sites More sharing options...
