Honda_boyd0.ob Posted February 24, 2008 Share Posted February 24, 2008 engine build:F20C if i wanted to build F20C from scrach wat are all the parts needed? like umm block , vales,cams, heads,etc but i need to know all the parts just make a list. i dont need a brand just the name of the parts Link to comment Share on other sites More sharing options...
Hatch92 Posted February 24, 2008 Share Posted February 24, 2008 crank rods pistons rings water pump oil pump oil pick up oil pan timing gears timing belt crank pully alternator valves springs/retainers Edit: Flywheel Link to comment Share on other sites More sharing options...
injen78 Posted February 24, 2008 Share Posted February 24, 2008 crankrods pistons rings water pump oil pump oil pick up oil pan timing gears timing belt crank pully alternator valves springs/retainers Edit: Flywheel dont forget new bearings(oem or acl),bolt kit(arp),gasket set(oem from honda),and you would want to rehone the block, Link to comment Share on other sites More sharing options...
delsol209 Posted February 24, 2008 Share Posted February 24, 2008 hoses, radiator, assembly lube, measurment instruments, piston ring compressor, and also you want to get the block balanced Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 24, 2008 Share Posted February 24, 2008 That covers the most of it. Oh yeah the two bigs parts to the engine are going to be TIME and MONEY Have fun. Link to comment Share on other sites More sharing options...
