jcfbaby Posted February 21, 2008 Share Posted February 21, 2008 i jus bought depo fog lights does how do i install it? any pictures to how to install my fog lights? Link to comment Share on other sites More sharing options...
XScarAudio Posted February 21, 2008 Share Posted February 21, 2008 there should have been a wiring diagram with the kit....basically, mount lights, run the 3 wires....usually there is a ground, power and some sort of relay wire coming from the switch to the lights. Link to comment Share on other sites More sharing options...
Pballer2005 Posted February 23, 2008 Share Posted February 23, 2008 red wire goes to switch then battery or something like that, black wire goes to a ground... Link to comment Share on other sites More sharing options...
rocknskulls Posted February 23, 2008 Share Posted February 23, 2008 first run your wires to where you want them then hook everything up there should be a red black and accessory. wires if its a simple setup run power from battery to switch run ground from a ground point that you make it should also have the ground wires from the fog light to the same ground then run that to the switch then the other wires from the fog light run to the accessory point on the switch thats it Link to comment Share on other sites More sharing options...
