musedrainfall Posted February 20, 2008 Share Posted February 20, 2008 so i just replaced the battery and battery fuse in my 98 civic and when i started up my car.. no bass. i checked my amp and the power light is a no go. i made sure that the power to the battery was secure and touching but still nothing. any suggestions? Quote Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 20, 2008 Share Posted February 20, 2008 Try a new wire to the amp and make sure you didn't blow the inline fuse (if you ran one) or the fuses on the amp. Also check your remote and ground wire. Get out the trust old multi meter and check the voltages on the lines. Quote Link to comment Share on other sites More sharing options...
musedrainfall Posted February 20, 2008 Author Share Posted February 20, 2008 Try a new wire to the amp and make sure you didn't blow the inline fuse (if you ran one) or the fuses on the amp.Also check your remote and ground wire. Get out the trust old multi meter and check the voltages on the lines. i'll make sure i didn't blow the fuses. if i have to buy new wire i'm screwed. boo money Quote Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 20, 2008 Share Posted February 20, 2008 If you check the voltage going with a multimeter that can tell you truely if you are getting power or not. Just double check the little stuff like fuses and give us a update. Quote Link to comment Share on other sites More sharing options...
musedrainfall Posted February 20, 2008 Author Share Posted February 20, 2008 If you check the voltage going with a multimeter that can tell you truely if you are getting power or not. Just double check the little stuff like fuses and give us a update. will do. thanks Quote Link to comment Share on other sites More sharing options...
