joe_112786 Posted February 20, 2008 Share Posted February 20, 2008 ok theres a guy whos selling it for 500 buckes but the front end is al smashed....wat motor is that? and would it fit in a hatch? im juss courious lol Link to comment Share on other sites More sharing options...
James Matteu Posted February 20, 2008 Share Posted February 20, 2008 wat motor is that? You are looking at an F22B1, in-line 4 cylinder, 2.2 liter, 16 valve, PGM-Fi + VTEC, and if no work has been done to it, it is likely naturally aspirated. It is the 145 horsepower weakling of the CL line. I am sure my HF breatherin will step in at this point, but I am pretty sure this is the standard motor that ended up in many 5G Accords. would it fit in a hatch? With enough money, you can drop a small-block V8 in your hatch. The question you should be asking is does this motor fit your needs. I would consider that most Accord owners either boost this motor or get rid of it altogether, at their earliest opportunity; i.e. you may be dissatisfied with its performance in the long run. Link to comment Share on other sites More sharing options...
joe_112786 Posted February 20, 2008 Author Share Posted February 20, 2008 You are looking at an F22B1, in-line 4 cylinder, 2.2 liter, 16 valve, PGM-Fi + VTEC, and if no work has been done to it, it is likely naturally aspirated. It is the 145 horsepower weakling of the CL line. I am sure my HF breatherin will step in at this point, but I am pretty sure this is the standard motor that ended up in many 5G Accords. With enough money, you can drop a small-block V8 in your hatch. The question you should be asking is does this motor fit your needs. I would consider that most Accord owners either boost this motor or get rid of it altogether, at their earliest opportunity; i.e. you may be dissatisfied with its performance in the long run. iight thcxs i was jus wandering lol now to find a cheeap ls for sale =( soo hard to find Link to comment Share on other sites More sharing options...
