joe_112786 Posted February 18, 2008 Share Posted February 18, 2008 ok we been trying for hours to get offf teh pully for the alternator...the one werew the case for the timing belt is.....how do we get it off? weve tred long wrnches and a air gun still no budge =( Link to comment Share on other sites More sharing options...
cranny Posted February 18, 2008 Share Posted February 18, 2008 why do you need to get the alternator pully off exactly? Link to comment Share on other sites More sharing options...
James Matteu Posted February 18, 2008 Share Posted February 18, 2008 Timing belt pulley, alternator pulley, which are you talking about. Take a deep breath and try again. Are you speaking of the crankcase pulley, the pulley that is physically attached to the alternator, or possibly a third pulley (this is called a tension pulley, but may not be on your motor). Link to comment Share on other sites More sharing options...
joe_112786 Posted February 18, 2008 Author Share Posted February 18, 2008 the big pully on the bottom connceted to the timing belt cover...one of the belts get connected to the alternator..need to change my timing belt....okkk changed the water pump and still no pressure and nothing on the bottom radiator hose..soo imm a go out and buy a new radiator and if thats not the problem then idk wat the hell is wrong lol Link to comment Share on other sites More sharing options...
Hatch92 Posted February 18, 2008 Share Posted February 18, 2008 the one on the bottom is the crank pulley Edit: you said you changed the thermostat right? Link to comment Share on other sites More sharing options...
James Matteu Posted February 18, 2008 Share Posted February 18, 2008 the big pully on the bottom connceted to the timing belt cover... This is probably besides the point, but to remove the crankcase pulley, you need: 1) pulley holder 2) 1/2" drive breaker bar to hold the pulley holder (36" in length) 3) 3/4" drive breaker bar to turn the pulley bolt (36" in length) 4) 19mm socket for the pulley bolt 5) 24" of 3/4" driver extension 6) scissor jack (OEM Honda Equipement from your trunk) Once you have all this equipment set up, it will take a minimum of pressure to loosen the crankcase pulley bolt. I loosened mine by barely stepping on the breaker bar. The bolt must be re-tightened to 185 ft-lbs, and should NOT be done with an impact driver (per Honda service manual instruction). I say it might be besides the point since it sounds like you have some other stuff going on there. Edit: pulley holder -$99 online 36" long, 1/2" drive, breaker bar -$40 at NAPA 36" long, 3/4" drive, breaker bar -$90 at NAPA 19mm Craftsman socket -$7 at Sears 24" of 3/4" driver extension -$80 at NAPA Honda jack -Free with car Knowing I can remove my crankcase pulley any time I want (without causing any damage) -Priceless Link to comment Share on other sites More sharing options...
joe_112786 Posted February 18, 2008 Author Share Posted February 18, 2008 ok got every thing off changed timing belt ...ok i changed the radiator and it still the same.... the bottom pipe is still cld and the top is a lil hot and were the thermastat sits is were it gets hot but doesent go past there now ive chnged the thermastat 3 times..no way i could get 3 baad ones....sooo nideas? Link to comment Share on other sites More sharing options...
James Matteu Posted February 18, 2008 Share Posted February 18, 2008 I get that your feeling the pipes for temp, but have you run the motor with the radiotor cap off to see if your getting pressure? Dumb question: have you flushed? Link to comment Share on other sites More sharing options...
joe_112786 Posted February 18, 2008 Author Share Posted February 18, 2008 ya i flushed it and ive tryed with cap off...i know wen im not getting pressure lol so u htink the thermastat might b sitting in wrong? or in hte wrong way... Link to comment Share on other sites More sharing options...
James Matteu Posted February 18, 2008 Share Posted February 18, 2008 That is possible, happened on my CRX, but it was upside-down and the system held air since the bleed port was on the wrong side. Link to comment Share on other sites More sharing options...
rocknskulls Posted February 18, 2008 Share Posted February 18, 2008 did you try bleeding the system as air can in the line can cause this. when you did the flush was it dirty or clogged any? Link to comment Share on other sites More sharing options...
Hatch92 Posted February 18, 2008 Share Posted February 18, 2008 i would try to flip the thrmo over and see if that works if not then you have a plug somewhere. and it's gonna be a big plug. Link to comment Share on other sites More sharing options...
joe_112786 Posted February 19, 2008 Author Share Posted February 19, 2008 ya were would i habve a plug though? i juss re did head...new raditor plus hoses..new theremastat..so were would it b i have no lcue lOL Link to comment Share on other sites More sharing options...
rocknskulls Posted February 19, 2008 Share Posted February 19, 2008 was it clean or did it have clogs? Link to comment Share on other sites More sharing options...
cranny Posted February 19, 2008 Share Posted February 19, 2008 its not 185. H and F series are 185 , K prolly too. B and D im almost sure is 130. Link to comment Share on other sites More sharing options...
joe_112786 Posted February 19, 2008 Author Share Posted February 19, 2008 u know the lil bleeder on the head to bleed the air out for anticoolant...well i snapped it tighting it last night ..now gotta go to the junk yards to look for a new one =( Link to comment Share on other sites More sharing options...
Kegger Posted February 19, 2008 Share Posted February 19, 2008 That's no good. But do like scott said and pull the thermostat and turn it around and see if it's does anything for ya. Link to comment Share on other sites More sharing options...
joe_112786 Posted February 19, 2008 Author Share Posted February 19, 2008 but the book tells me to put it i nthe way i have it with the spring facing inword ... Link to comment Share on other sites More sharing options...
delsol209 Posted February 19, 2008 Share Posted February 19, 2008 yea thats the correct way i mean the best bet for you is to do a pressure test and see if you have pressure you will find out that way Link to comment Share on other sites More sharing options...
James Matteu Posted February 19, 2008 Share Posted February 19, 2008 its not 185. H and F series are 185 , K prolly too. B and D im almost sure is 130. MY BAD OOPS!! That is for C series. My bad! Link to comment Share on other sites More sharing options...
1.6literv8eater Posted February 26, 2008 Share Posted February 26, 2008 ok we been trying for hours to get offf teh pully for the alternator...the one werew the case for the timing belt is.....how do we get it off? weve tred long wrnches and a air gun still no budge =( HEY JOE I GOT A IDEA ! , JUNK THAT PEICE !!!!! lolool my civic is gunna beat your just watch ! Link to comment Share on other sites More sharing options...
