Prangy Posted February 16, 2008 Share Posted February 16, 2008 What size wire do I use. I was thinking like 10? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted February 16, 2008 Share Posted February 16, 2008 what are you going to have it kill? Ignition? Fuel pump? Power to everything? Link to comment Share on other sites More sharing options...
Prangy Posted February 16, 2008 Author Share Posted February 16, 2008 I am goign to do the fuel pump and is it possible to run one to the starter? I would do the ignition to, where is the wire running for that one and where would i cut it? what color is the wire for the fuel pump that gives it power? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted February 16, 2008 Share Posted February 16, 2008 10 ga is way overkill for your fuel pump, and 10 ga would be sufficient for your starter solenoid. use a relay for the starter. and you wouldn't have to run any heavy wire. just break the line, and put in a 30A relay thats toggled by your switch. Link to comment Share on other sites More sharing options...
Prangy Posted February 16, 2008 Author Share Posted February 16, 2008 what ga should i use then good sir? for the fuel pump? thanks buddy Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted February 16, 2008 Share Posted February 16, 2008 well you could just put a break in that line too, pop in a relay, and just run one small wire to your switch (switched +) and the other directly to ground. and bingo, 1 wire ran and it works great. same with starter. Link to comment Share on other sites More sharing options...
Prangy Posted February 16, 2008 Author Share Posted February 16, 2008 Hey pyro i forgot to ask what color is the wire for the fuel pump that I should cut? For my car do I just take off the back seat and unscrew the white thingy? and the wires will be right htere then? Thanks dude Link to comment Share on other sites More sharing options...
90IntegraC1 Posted February 16, 2008 Share Posted February 16, 2008 Killswitch Engage = decent band. that is all. Link to comment Share on other sites More sharing options...
Hatch92 Posted February 16, 2008 Share Posted February 16, 2008 kill switch isn't too bad. not my favorite Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted February 16, 2008 Share Posted February 16, 2008 Hey pyro i forgot to ask what color is the wire for the fuel pump that I should cut? For my car do I just take off the back seat and unscrew the white thingy? and the wires will be right htere then? Thanks dude dunno what white thing your talking about, but just find the wires one should be hot, and the other ground i'd imagine. Use a test light to find the hot, and cut. solder either end onto a relay, on pins 30, and 87. It doesn't matter which ones to which post. then take either 85, or 86, run a small wire to a ground, and then take the other pin, and run it to your switch. run a wire from your switch, to a constant hot source. button it up, and your done. Link to comment Share on other sites More sharing options...
