check engine
jcfbaby
Posted
my check engine light shows and i have 180xxx miles my mechanic said it could be the o2sensor is my car fine?
Posted
You can ride with the cel... but you wont pass any emissions test...o2 sensors arent that expensive, and are pretty easy to change.. just pick on up and change it..
Posted
you can always go to autozone and if the car is obd 2 then can scan it too make sure it is the o2 sensor. Pick on up while you are there.
Posted
thanks guys i bearly got in tha honda life and so far im lovin it
Posted
No problem, Hondas are easy to understand and great learner cars.
If you have any more questions, feel free to ask.
Posted
you dont need autozome , you can get the codes out of the car yourself easily.
Posted
If you don't have a diagnostics reader, take it to autozone and they will get them for free. They just wont tell you what they mean. You can find out on line though.
Posted
behind your passenger kick panel , theres a rubber clip holder. inside that clip holder if its never been out , is a blue 2 pin connector. take it out , cross those 2 wires by jamming a piece of wire or paper clip in both sides. turn the key to on position , bt not starting it , and the engine light will flash the codes , long blink=10 , short blink=1.
Posted
the blinking thing is awesome...only doesn't work if you have a very short attention span <---me hehe
I just go get the obd reader and look up the codes from the list I carry in my purse... :D
