zoomzoom Posted February 12, 2008 Share Posted February 12, 2008 im lookin at a turbonetics turbo kit which the owner tells me it pushes about 15 pnds of boost it sounds the way i want but im nt sure what probs has ne 1 run into with a turbo kit Quote Link to comment Share on other sites More sharing options...
Tubbith Posted February 12, 2008 Share Posted February 12, 2008 Make sure you know everything about turbo kits and how they work with your motor. You would want to buy a turbo kit, and in 3 months be buying a motor.. Quote Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 12, 2008 Share Posted February 12, 2008 I agree with tubbith on this one. Quote Link to comment Share on other sites More sharing options...
delsol209 Posted February 12, 2008 Share Posted February 12, 2008 yup yup i mean are you going to build the motor? cause it can push 30psi but that dont matter if your running a stock block, so choose one that is going to go with wat you got now or just wait to do it right Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted February 12, 2008 Share Posted February 12, 2008 yup yup i mean are you going to build the motor? cause it can push 30psi but that dont matter if your running a stock block, so choose one that is going to go with wat you got now or just wait to do it right Actually, the T3/TO4E that comes with the turbonetics kit maxes out at 26psi. 15psi is way too high for a stock motor with that kit. That kit comes new with an 8psi wastegate spring and that's about the most I'd run without lower compression. Quote Link to comment Share on other sites More sharing options...
delsol209 Posted February 12, 2008 Share Posted February 12, 2008 actually i wasnt talking about that kit i was generally speaking Quote Link to comment Share on other sites More sharing options...
