nickysamm Posted February 3, 2008 Share Posted February 3, 2008 I ordered myself a shortshifter for my del sol and am curious to see if you need to dismantle the gearbox to gain access or if everything can be easily accessed by simply removing the centre panel from the cockpit? Quote Link to comment Share on other sites More sharing options...
delsol209 Posted February 3, 2008 Share Posted February 3, 2008 you have to remove the center council and remove the plate that holds the shifter boot together, and then you have to get a hammer and a punch to hit out the pin that holds in the shift linkage to the transmission and thats it Quote Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted February 3, 2008 Share Posted February 3, 2008 Its pretty easy, You do most from underneath the car. Unscrew the shiftknob, then get under the car and remove the two bolts that hold the linkage to the chassis. You should be able to figure out how to remove the old shifter and put the new one in its place from there. Its pretty straightforward. Quote Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted February 3, 2008 Share Posted February 3, 2008 You dont have to take out the bitch pin just to install a short shifter, or is that what you are trying to say? I have never had to on the few hondas I have put one in on. Quote Link to comment Share on other sites More sharing options...
TS John Posted February 4, 2008 Share Posted February 4, 2008 Me neither. My B and M one came with instructions that were very easy to follow alone even though I had never done that before. Make sure you really tighten anything down that you've loosened or your shifter will rattle like mine did and then you have to get under there again and fix it. That's a pain. Quote Link to comment Share on other sites More sharing options...
Kegger Posted February 4, 2008 Share Posted February 4, 2008 The only thing I've ever had to pop a bitch pin for is tranny swaps or linkage swaps. Short shifters are waaaaay too easy. Quote Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted February 4, 2008 Share Posted February 4, 2008 Shorter throws when shifting. Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 4, 2008 Share Posted February 4, 2008 quicker response times, faster shifts, less time off the throttle Quote Link to comment Share on other sites More sharing options...
SiR JDM Del Sol UK Posted February 17, 2008 Share Posted February 17, 2008 I ordered myself a shortshifter for my del sol and am curious to see if you need to dismantle the gearbox to gain access or if everything can be easily accessed by simply removing the centre panel from the cockpit? Some models already come with a short shift, JDM SiR. UK VTI and I would probably say the US equivalent of both. Check before you buy!!! Quote Link to comment Share on other sites More sharing options...
SiR JDM Del Sol UK Posted February 17, 2008 Share Posted February 17, 2008 Me neither. My B and M one came with instructions that were very easy to follow alone even though I had never done that before. Make sure you really tighten anything down that you've loosened or your shifter will rattle like mine did and then you have to get under there again and fix it. That's a pain. BTW Your ride looks nice and clean, Slap a set of 17" on her lower by 35mm with an MS Design body kit and the birds will flock, my god your nether regions will be red raw!!!! Enjoy !!! Quote Link to comment Share on other sites More sharing options...
SiR JDM Del Sol UK Posted February 17, 2008 Share Posted February 17, 2008 BTW Your ride looks nice and clean, Slap a set of 17" on her lower by 35mm with an MS Design body kit and the birds will flock, my god your nether regions will be red raw!!!! Enjoy !!! When I say 35 i meen 30 or 40 your decision!!!!! Quote Link to comment Share on other sites More sharing options...
jvc7065 Posted May 5, 2008 Share Posted May 5, 2008 what brand of Short/Shifter is the best B&M skunk2 J racing ect. Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted May 5, 2008 Share Posted May 5, 2008 it depends on what you like. if you have felt all of them then you can choose. i've used B&M and Skunk2, personally i like the skunk2 more. Also this was a dead thread. Quote Link to comment Share on other sites More sharing options...
Orca89 Posted July 22, 2008 Share Posted July 22, 2008 Ok, I realize this is a dead thread, but just in case someone comes along looking for a how-to guide, here you go. http://www.twmperformance.com/manuals/88-0...on%20Manual.pdf Quote Link to comment Share on other sites More sharing options...
