Turns over but no start?
vmaxster
1989 civix dx stopped running as headlights/dash lights went dim on way from work last night. Had battery checked and was bad. Bought new battery and changed out but engine turns over but no start? Plenty of gas in tank.
Possibly a tune-up issue? Also make sure the terminals are clean.
just pull the wire off the end of the plug, stick a screwdriver into the wire and lay it over the valve cover or on the block then have someone turn it over and watch for a spark. if no spark check the wire and do it again. if still no spark then it's prolly the cap and rotor.
Edited by Hatch92
You people think you've been juiced.
Try getting hit with over 400 volts on a three-phase contactor while working on a goddamn chiller. If you don't hit the voltage with the back of your hand, it WILL make you grab on.
