95 vtec milano Posted February 1, 2008 Share Posted February 1, 2008 Am replacing my thermostat on a 95 vtec, but can't get at the lower 10mm bolt. Should I remove the temp sender switch, which is just above it, or do you have to remove the starter, which would give me more room? Have searched the forums without luck. Thanks Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 1, 2008 Share Posted February 1, 2008 year make and mokdle of car would help. and you may have to remove the switch. Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted February 1, 2008 Share Posted February 1, 2008 year make and mokdle of car would help. and you may have to remove the switch. well he said 95 vtec, and its posted in the sol forum...youre smart you can figure it out :drew: Quote Link to comment Share on other sites More sharing options...
95 vtec milano Posted February 3, 2008 Author Share Posted February 3, 2008 Got it by removing the air intake and temp sender switch connector, not the switch itself. Just enough room with your left hand to get it with a small 10 mm gear wrench. Used honda antifreeze too after searching the web, as no silicates which apparently can lead to water pump leaks. Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 3, 2008 Share Posted February 3, 2008 ok so 95 vtec can be taken 2 ways a 95 vtec model or a 95 si with a d16z6 vtec motor. got me meow? lol i've been drunk the last couple days Quote Link to comment Share on other sites More sharing options...
