nickysamm Posted January 27, 2008 Share Posted January 27, 2008 I have a del sol with a 1490cc SOHC VTEC engine and instead of replacing the engine with a b16a I'd like to upgrade this engine within its limits without spending too much money that would make more sense to swap the engine all together. Currently all I've upgraded is the intake filter and replaced it with a short ram and cone filter and a stainless steel full exhaust system. Your suggestions? PS> You can check out my car at www.vti815.co.nr and leave your comments there too. thanks. Quote Link to comment Share on other sites More sharing options...
James Matteu Posted January 27, 2008 Share Posted January 27, 2008 Your suggestions? You can start by removing the TCM Electric Supercharger. It is merely a gimick. Quote Link to comment Share on other sites More sharing options...
nickysamm Posted January 27, 2008 Author Share Posted January 27, 2008 You can start by removing the TCM Electric Supercharger. It is merely a gimick. Point taken and I agree, but any suggestions about how to power up the engine without pumping too much cash into it? Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted January 27, 2008 Share Posted January 27, 2008 is a header part of your "full exhaust system" if not you can get one Quote Link to comment Share on other sites More sharing options...
Speed_Safely Posted January 27, 2008 Share Posted January 27, 2008 Intake, Headers, Exhaust, Clutch, Flywheel, Short Shifter, and maybe a Simple MSD set-up. Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted January 27, 2008 Share Posted January 27, 2008 Intake, Headers, Exhaust, Clutch, Flywheel, Short Shifter, and maybe a Simple MSD set-up. Currently all I've upgraded is the intake filter and replaced it with a short ram and cone filter and a stainless steel full exhaust system. and i havent heard anything good come from MSD ignitions unless the motor is highly modified Quote Link to comment Share on other sites More sharing options...
zimmy709 Posted January 28, 2008 Share Posted January 28, 2008 you could do a mini-me head swap... throw a d16z6 head on it with a thinner head gasket to raise your compression as well. Quote Link to comment Share on other sites More sharing options...
Speed_Safely Posted January 29, 2008 Share Posted January 29, 2008 and i havent heard anything good come from MSD ignitions unless the motor is highly modified Would you rather have me say "Put some NGK plugs and some Nology wires"?! Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted January 29, 2008 Share Posted January 29, 2008 (edited) why not? there are alot of built cars that run factory plugs, wires, and coil packs Edit: OP if you plan to keep the motor than i'd suggest get the header out of the way since you already have the intake and catback from the soudns of it. then i'd portmatch the intake and exhaust side of the head (if you know how to do it), then do a cam and clutch/flywheel combo that would keep you satifidies for a while. That is until you want more than you'd prolly have to go high compression N/A or boost it. You can boost those little d-sereis motors pretty cheap and easily. Edited January 29, 2008 by Hatch92 Quote Link to comment Share on other sites More sharing options...
