fishswimfast Posted January 25, 2008 Share Posted January 25, 2008 i just bought a 94 prelude. everything works in the car except the cigarette adapter. when i plug my radar detector in, it doesnt work. i checked the fuse box under the dash and in the engine bay and i can't find any place that is labeled cigarette adapter. i checked the acc fuse and it is fine. could it be something else or is it the cigarette adapter itself? Quote Link to comment Share on other sites More sharing options...
speedfreek09 Posted January 25, 2008 Share Posted January 25, 2008 just make sure the ignition is on and use a test light or multimeter to test all the fuses thats usually what i do. plus if you have other blown fuses you can fix them too. i cant count all the times i have fixed customers cars problems just because they havent checked all the fuses Quote Link to comment Share on other sites More sharing options...
fishswimfast Posted January 26, 2008 Author Share Posted January 26, 2008 there is no cigarette fuse. what fuse would it be connected to Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted January 26, 2008 Share Posted January 26, 2008 mine is the same as my stereo, check that one Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted January 26, 2008 Share Posted January 26, 2008 Look in your owners manual and it should give a breakdown of the fuses. Also check the fuses under the hood and a lot of cars have a second fuse box in the passenger side footwell. If all else fails, pull each fuse, one at a time, and see if any of them are blown. If that doesn't work, track down an acc power with a tester light (off the ignition would work) and run a new wire to the cigarette lighter. This would take me about 15 minutes to do all of that. If you're not very familiar with wiring then it should still take under an hour. Quote Link to comment Share on other sites More sharing options...
fishswimfast Posted January 28, 2008 Author Share Posted January 28, 2008 ok i found out that its not the fuse. there's a male plug with four wires connected to the adapter. i guess when the head unit was installed the adapter got unplugged. does anyone know where the plug connects to Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted January 28, 2008 Share Posted January 28, 2008 yeah there should be the female plug around there. you might have to remove the stereo because they probably unplugged it to take the dash trim off, then put the new deck in, and the plug got pushed back. its there, just do some searchin Quote Link to comment Share on other sites More sharing options...
