block question
Currpt_God
so i was going to go pick up this bare ls block for my lsvtec build the guy wants $100 but then i found a GSR block for $120..... is there any difference in strength between the blocks and i can put a 99 si b16 head direct bolt on to a GSR block right? so no need for lsvtec?
get the GSR block. it'll be extreamly worth the extra $20 plus you can put a vtec head on a GSR block for alot less money considering the block was built for it.
Edit: If you put the B16 head on the GSR block and run a little bit higher compression then you would have a "Poor Mans" type-r if i remember correctly.
Edited by Hatch92
