rocknskulls Posted January 23, 2008 Share Posted January 23, 2008 (edited) hey im wondering if a 1998 honda civic engine will fit in a 1993 it looks to be the same engine they also have the same 8th vin number pic of the engine my engine Edited January 27, 2008 by rocknskulls Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted January 23, 2008 Share Posted January 23, 2008 i think it's 160 +or- 15 Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted January 27, 2008 Author Share Posted January 27, 2008 bump changed some things Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted January 27, 2008 Share Posted January 27, 2008 yes you can swap in a 98 civic motor. theres a few different ones from that year so check it out Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted January 27, 2008 Author Share Posted January 27, 2008 (edited) ok thanks the one im looking at seems to be the same any other way to tell other than the vin ??? and do i need to transfer the computer too or can i use the one i have already in the car??? Edited January 27, 2008 by rocknskulls Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted January 27, 2008 Share Posted January 27, 2008 look whats stamped on the block. should look something like this. wont be a b18 though, just a pic for reference Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted January 27, 2008 Author Share Posted January 27, 2008 ok thanks ill take a look at that Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted January 27, 2008 Author Share Posted January 27, 2008 still wondering if id need to transfer the computer or use the one already in my car Quote Link to comment Share on other sites More sharing options...
TheJGB3 Posted January 31, 2008 Share Posted January 31, 2008 (edited) First of all the '93 is OBDI and the '98 is OBDII, so you will have to convert the engine harness plugs. Second of all Honda does not designate the engine with the VINs 8th character, like most manufacturers do. I had two 2000 Civic EXs, one had a 4 and the other had a 5 for the 8th character of the VIN, but they both had a D16Y8 engine. Also to do this swap you will need the tranny and half shafts with the donor engine too. Edited January 31, 2008 by TheJGB3 Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted January 31, 2008 Share Posted January 31, 2008 the motor will swap right over no problem however you will need to wire some things to make the OBDI car compatable with the ODB2 motor or you could swap a OBDI dizzy to the y8 motor and use your stock O2 sensor and then jsut run a vtec wire to the p28 ecu and you would be golden. Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted February 4, 2008 Author Share Posted February 4, 2008 (edited) ok first of all the car sold for more then i was willing to give for it so i looked for another engine and found a 1995 honda civic 1.5l (witch i found out my car has by looking at the block the valve cover is from a 1.6 and that threw me off ) anyways just wanted to know if it would bolt up to my transmission the engine i have now is d15b8 and ill get the info to the other engine tomm and the 1.5l in my car is the ex edtion and i think this one's is the dx will it mount it has the same 6TH vin which is how honda does their engines i found that out Edited February 4, 2008 by rocknskulls Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted February 5, 2008 Share Posted February 5, 2008 you coulda thrown a period or two in there to clean it up. so what transmission are you asking about, bolting up to which motor? Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 5, 2008 Share Posted February 5, 2008 (edited) any d-series motor will bolt to any d-series transmission, as long as it's a d-series Edit: good meow? Edited February 5, 2008 by Hatch92 Quote Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted February 5, 2008 Share Posted February 5, 2008 any d-series motor will bolt to any d-series transmission As long as its a d-series..... Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 5, 2008 Share Posted February 5, 2008 ok i forgot that line amended Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted February 5, 2008 Author Share Posted February 5, 2008 (edited) ok thats good to know any one want to buy my old 1 when i pull it out or my cf hood just want to see wat prices mainly but considering selling found out to day the new engine im gettting is a d15b7 mine is a d15b8 whats the difference??? andwill it mount on the same mounts as the d15b8?? Edited February 5, 2008 by rocknskulls Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted February 6, 2008 Author Share Posted February 6, 2008 can anybody help me here???? i need to no im just waiting to see if will mount and all that ive got the money Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 6, 2008 Share Posted February 6, 2008 the D15b8 is an 8 valve economy motor. the D15b7 is a 16 valve motor. still in the economy aspect but a little more torque than the motor you have and it would be a jump in horsepower Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted February 6, 2008 Author Share Posted February 6, 2008 still same engine mounts?? and wil the tranny that i have hold up to all that??? and does it use the same dis. it doesnt come with one all it comes with is the water pump im going to have to do alot of transfering and need to make sure i dont have to buy anything different thanks for the help Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 7, 2008 Share Posted February 7, 2008 yes its the same mounts, and your tranny will take the power hell my d15b8 tranny was mounted to a z6. everything is the same and is a direct plug and play swap. all d-series motrs are interchangablew. parts and internals, as long as it id another d-series motor. everything bolted onto a d-series motor is interchangable with another d-series motor. Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted February 7, 2008 Author Share Posted February 7, 2008 alright thanks for the help i wish i could help people out more on here but i just dont know much about hondas yet i had a nissan for the longest time im going to order my engine tommorrow yay!! Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted February 9, 2008 Author Share Posted February 9, 2008 going from d15b8 to d15b is is worth it or is there some other engine that would be better for the app.. i only have $800 to spend Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 9, 2008 Share Posted February 9, 2008 a z6 would be a better swap. Quote Link to comment Share on other sites More sharing options...
rocknskulls Posted February 9, 2008 Author Share Posted February 9, 2008 how much does one normally cost like i said i only have $800 to spend and if i get the d15b i can put a new clutch in too i think second is going out on mine Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 9, 2008 Share Posted February 9, 2008 you should be able to pick up a Z6 motor and buy te P28 ecu for around $400. then all you have to do is run 1 wire to the vtec solenoid. Then you can also replace the clutch and flywheel is youfell for the same price you would of paid for that $800 motor. Quote Link to comment Share on other sites More sharing options...
