forevernewbie Posted January 10, 2008 Share Posted January 10, 2008 I have a 2004 Accord (EX 4 cyl) which runs great. Had no major issues (except brake judder) under warranty. Now at 40 K miles showing an slight oil leak. It is near or above the oil filter. I thought it was becos of dealer not tightening oil filter properly. Got that checked out. Dealer says it could be oil pressure sending unit or :sad: some solenoid but not loose oil filter !! I don't think this is common for Honda. Any way what you guys think ? Any body had similar issue? How much could be bill (approximate)? I am planning to get it done at the dealer. He is planning to do the dye test to find the exact source of the leak. I am DIY guy for small things. But with 10 degree weather and tight access to oil pressure sensor it is not worth it. I am planning to go to dealer I am really looking for your opinion. :bow: Quote Link to comment Share on other sites More sharing options...
xer0 Posted January 10, 2008 Share Posted January 10, 2008 inmy jeep my oil sending unit went and was shooting oil out of it like i cut my jeeps jugular Quote Link to comment Share on other sites More sharing options...
ZX9RBART Posted January 11, 2008 Share Posted January 11, 2008 It's a 10 minute job. save your money. Just take off your oil filter (yes you can reuse it). pull off the plug and unscrew the sending unit...i just did this as mine was leaking, new sending unit was 8 bucks at advanced auto. The sending unit is brass so thread sealant is not needed but i used some anyways. Quote Link to comment Share on other sites More sharing options...
