rozensky Posted January 6, 2008 Share Posted January 6, 2008 I installed a camber kit on my 92 accord and now my tires are rubbing on the inner fender. what can i do to fix this so it doesnt eat my tires? Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted January 6, 2008 Share Posted January 6, 2008 the tires are leaning into the inner fender well? if so lower the car or move the camber to so the top of the tire comes out more its a + effect if i remember correctly. thats what you need to do. you have a negative camber right now i beleive you need a 0 or less of a negavtive. Quote Link to comment Share on other sites More sharing options...
J C L i T Posted February 1, 2008 Share Posted February 1, 2008 the tires are leaning into the inner fender well? if so lower the car or move the camber to so the top of the tire comes out more its a + effect if i remember correctly. thats what you need to do. you have a negative camber right now i beleive you need a 0 or less of a negavtive. the camber kit should have FIXED any rubbing that may have occured prior to installing the kit. if its now running after, clearly its not set right and needs adjustment. Quote Link to comment Share on other sites More sharing options...
toyota7015 Posted February 19, 2008 Share Posted February 19, 2008 (edited) have you had it aligned?? if you tell the guy that does the alignment that you camber kits and a coke i bet you he will adjust it for you.. also did you put it on all 4 wheels?? if so and if the fender is chewing the wall of your tire and not the top, you can "roll" your fender wells, back in the day we used to do it with a wooden bat and some guts!! good luck Edited February 19, 2008 by toyota7015 Quote Link to comment Share on other sites More sharing options...
