alex37211 Posted December 24, 2007 Share Posted December 24, 2007 Two of them are busted. I'm putting this 97 GSR motor into my 95 Civic EG. Can I use mounts from a 91 Integra LS? Cause' I have access to those for free. Also, should I buy inserts for them even if they're in good shape? I don't have a lot of money to spend after buying this Teg. Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted December 24, 2007 Share Posted December 24, 2007 you would be better off just buying new mounts. polyurethane if possible. Quote Link to comment Share on other sites More sharing options...
solmeistro Posted December 26, 2007 Share Posted December 26, 2007 i agree, by some good mounts, but if you need to yes the ls motor mounts will work, all b-series engines use the same mounts. if you want, you can by some polyeurothane out of a tube from home depot and fill the mounts up completely on the inside and it'll hold just as strong as after markets... Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 27, 2007 Share Posted December 27, 2007 i agree, by some good mounts, but if you need to yes the ls motor mounts will work, all b-series engines use the same mounts. if you want, you can by some polyeurothane out of a tube from home depot and fill the mounts up completely on the inside and it'll hold just as strong as after markets... the driver side mount is not the same as the one you have has 3 bolts and the 91 has 2. you would have to change the mount bracket. it looks like it was in an accident, if so check the mount bracket to the engine and see if it cracked the block or pulled the threads out....... Quote Link to comment Share on other sites More sharing options...
cranny Posted December 27, 2007 Share Posted December 27, 2007 none of them are the same from a 91 , not one , lol. buy some new ones , try ebay. Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted December 27, 2007 Share Posted December 27, 2007 or go to an auto parts store and buy another set. Quote Link to comment Share on other sites More sharing options...
