ZX9RBART Posted December 15, 2007 Share Posted December 15, 2007 I understand how sport mode is supposed to work but mine seems slightly retarded. When in sport mode the car shifts at lower rpm's and much smoother than when in regular mode. Under light throttle in normal it usually shifts into each gear at 3000 rpm with a healthy jerk, in sport mode it will shift at 2500 rpm and much smoother...any ideas??? Link to comment Share on other sites More sharing options...
ZX9RBART Posted December 26, 2007 Author Share Posted December 26, 2007 I understand how sport mode is supposed to work but mine seems slightly retarded. When in sport mode the car shifts at lower rpm's and much smoother than when in regular mode. Under light throttle in normal it usually shifts into each gear at 3000 rpm with a healthy jerk, in sport mode it will shift at 2500 rpm and much smoother...any ideas??? ??? Link to comment Share on other sites More sharing options...
wannaBstuntin Posted December 26, 2007 Share Posted December 26, 2007 wtf is sport mode? anyways, i think shifting around 3K should give you the smoothest transition. 2500 isn't that big of a difference. what does 'sport mode' do when you're heavy on the throttle? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 27, 2007 Share Posted December 27, 2007 It is supposed to raise the shift point, so it stays in the gears longer. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 27, 2007 Share Posted December 27, 2007 it's also supposed to have a "Harder" shift Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 27, 2007 Share Posted December 27, 2007 I think it is like the "push here to cross" buttons on traffic light poles. they are only a button, not hooked up to anything, but make you believe you are actually doing something when you press it. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 27, 2007 Share Posted December 27, 2007 thats a possibility too. soo it's like 85% of the cross walk signs in NYC lol Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted December 27, 2007 Share Posted December 27, 2007 its a placebo button if you will. Link to comment Share on other sites More sharing options...
ZX9RBART Posted December 30, 2007 Author Share Posted December 30, 2007 its a placebo button if you will. Wow...such informative responses. Link to comment Share on other sites More sharing options...
