95exd16z6 Posted December 23, 2007 Author Share Posted December 23, 2007 EDIT: im plannin on honing the cylinder head, port and polishing the head after practicin on beamer heads, puttin in a set of arias 9.5:1 pistons and eagle rods, a new set of bearings from idk who. gettin a metal head gasket, and takin my time on everything i do, reading the chiltons before i put anything back together. how does this sound to everyone? any coments or suggestions? plannin on puttin the motor in a del sol and boostin it with a t3/t4 turbo runnin 6-10 pounds of boost and all the accoutremal that go with. Link to comment Share on other sites More sharing options...
cranny Posted December 23, 2007 Share Posted December 23, 2007 just use an OEM head gasket and get a can of copper spray. Link to comment Share on other sites More sharing options...
Ben. Posted December 23, 2007 Share Posted December 23, 2007 OEM rod bearings are good, are they not Cranny? Or would you recommend ACL? Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 23, 2007 Share Posted December 23, 2007 OEM rod bearings are good, are they not Cranny? Or would you recommend ACL? honda bearing or acl's are good. just get good clearances. Link to comment Share on other sites More sharing options...
Hatch92 Posted December 23, 2007 Share Posted December 23, 2007 honda bearings are cheaper are't they? Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 23, 2007 Share Posted December 23, 2007 honda bearings are cheaper are't they? from what i know they cost more. I get a set of bearing mains,ros,trust washers for 60 and the rings for another 45. Link to comment Share on other sites More sharing options...
cranny Posted December 23, 2007 Share Posted December 23, 2007 personally , as you guys have seen in some of my writeups , i like clevite bearings. and if for some reason i cant use them , i like OEM. i dont use ACL bearings. but you cant go wrong with OEM busted , no matter the setup. Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 24, 2007 Share Posted December 24, 2007 personally , as you guys have seen in some of my writeups , i like clevite bearings. and if for some reason i cant use them , i like OEM. i dont use ACL bearings. but you cant go wrong with OEM busted , no matter the setup. hey cranny what type of write ups do you do here? Can I read some of them, as i'm new and would like to see what we can write in here that might help others. let me know bro Link to comment Share on other sites More sharing options...
