Repsol Posted November 27, 2007 Share Posted November 27, 2007 I've noticed it ran a little hot from time to time. While sitting in Hardees drive through last night, The temp. gauge was nearly 1.5/8 from the (H). I don't know if it's a headgasket going bad, from all the High RPM. >_> Could be a thermostat, or I just need coolant. <--- Haven't checked it yet. Doh. Link to comment Share on other sites More sharing options...
James Matteu Posted November 27, 2007 Share Posted November 27, 2007 Sitting in the Hardees drivethrough? That's your cholesterol gauge going up, not the temp. Link to comment Share on other sites More sharing options...
Hatch92 Posted November 27, 2007 Share Posted November 27, 2007 i'd say check the coolant level if it's good. spend the $10 and replace the thermostat. Then if it still is ovr heating i'd look into maybe the fan not workin properly or maybe a head gasket. Also check the coolant coler to see if oil is in it and check the oil to see if water is in it. If either of those is true then head gasket is toast. Link to comment Share on other sites More sharing options...
Repsol Posted November 27, 2007 Author Share Posted November 27, 2007 I'm pretty sure the thermostat is sticking. It has been fine all day today. Time to look into a new one. Thanks for the help. Link to comment Share on other sites More sharing options...
1ofAkindDelSol Posted November 27, 2007 Share Posted November 27, 2007 Thats funny. the last time my car over heated it was because i had no oil in it. Solution to a long lasting del sol... (Pod guages) I got an oil press so that wont happen again, got an air fuel ratio so i kno how my car is running, and i got a volt guage so i kno when to give my alt and batt a break from the sterio. Keep it in mind. Link to comment Share on other sites More sharing options...
Repsol Posted November 27, 2007 Author Share Posted November 27, 2007 Can't be oil. Just got it changed recently. I mean I burn oil, but not that much. I do want a gauge though. Link to comment Share on other sites More sharing options...
Ben. Posted November 27, 2007 Share Posted November 27, 2007 Just because you got it changed..? That means nothing. Rotfl. Link to comment Share on other sites More sharing options...
Repsol Posted November 28, 2007 Author Share Posted November 28, 2007 Neither do you. GTFO. Link to comment Share on other sites More sharing options...
Hatch92 Posted November 28, 2007 Share Posted November 28, 2007 what? Link to comment Share on other sites More sharing options...
Ben. Posted November 28, 2007 Share Posted November 28, 2007 Neither do you. GTFO. LMAO! YOU BUTTHURT KIDDO? Yea. Let's get the overheating problem solved before we go ordering any EBAY turbo setups. Link to comment Share on other sites More sharing options...
Xeryon Posted November 29, 2007 Share Posted November 29, 2007 LMAO! YOU BUTTHURT KIDDO? Yea. Let's get the overheating problem solved before we go ordering any EBAY turbo setups. Link to comment Share on other sites More sharing options...
zimmy709 Posted November 29, 2007 Share Posted November 29, 2007 deff check into the fan thing... i had this problem where my fan ran like a gem until it got hot... haha great timing for a rad fan to quit working, but it always ran great cool... heated up and wouldn't run changed out the temp sensor for the fan checked all wiring even hardwired the fan to run all the time and that is what the problem turned out to be... changed out the fan and no problems. probably not a very common thing to happen, but worth a good check. Link to comment Share on other sites More sharing options...
