dohc1991integra Posted November 22, 2007 Share Posted November 22, 2007 I know what everything does...(and yes i read the turbo neccessities thread ) But can u guys just answer some Q's i have cause like the thread says...why put something on ur car that u know nothing about. so i wana know it all I wana start a hatch build...boosted, b18 if all goes well. this will happen over the nxt couple of years. im trying to find a nice hatch now. For now im doing all the planning and saving! lol It sounds stupid but, just explain to me wat connects to what. i know all the components im just confused in which order they go in.lol haha im still learning thanx to all dont hate plz Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted November 22, 2007 Share Posted November 22, 2007 I'd suggest getting some books, such as "Maximum boost" by corkey bell. what do you want to know? like how the turbo is bolted on, and where the intake piping goes? hot side - header, wastegate, turbo, exhuast, cold side - air filter, turbo, intercooler, bov, throttle body or.... Link to comment Share on other sites More sharing options...
dohc1991integra Posted November 22, 2007 Author Share Posted November 22, 2007 I'd suggest getting some books, such as "Maximum boost" by corkey bell. what do you want to know? like how the turbo is bolted on, and where the intake piping goes? hot side - header, wastegate, turbo, exhuast, cold side - air filter, turbo, intercooler, bov, throttle body or.... yeah thats all and how do u raise and lower boost? Link to comment Share on other sites More sharing options...
Hatch92 Posted November 22, 2007 Share Posted November 22, 2007 waste gate springs or boost controllers. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted November 22, 2007 Share Posted November 22, 2007 all the controller is, is a restriction on the vacuum line to the wastegate. makes the wastegate "see" a small amount of boost. or make is "see" no boost until you reach your desired pressure, then opens the restriction to let the wastegate open. you can keep the wastegate shut until the last possible moment, then open it. this lets you reach max boost quicker, because it isn't bleeding any exhaust off until your at max boost. Link to comment Share on other sites More sharing options...
Hatch92 Posted November 22, 2007 Share Posted November 22, 2007 true but it's smarter than swapping out the springs in the waste gate. Link to comment Share on other sites More sharing options...
blackdelsol Posted November 23, 2007 Share Posted November 23, 2007 waste gate springs or boost controllers. like Pyrorocketeer said, the wastegate is the only thing that controls boost on a turbocharged engine. I'd suggest getting some books, such as "Maximum boost" by corkey bell. what do you want to know? like how the turbo is bolted on, and where the intake piping goes? hot side - header, wastegate, turbo, exhuast, cold side - air filter, turbo, intercooler, bov, throttle body or.... sorry to correct you, but the turbine and the compressor should not be listed as the same thing. intake filter->compressor->intercooler->bov->TB->engine->exhaust manifold->wastegate->turbine->dp and exhaust Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted November 23, 2007 Share Posted November 23, 2007 both sides of the turbo are considered turbines..... Link to comment Share on other sites More sharing options...
dohc1991integra Posted November 24, 2007 Author Share Posted November 24, 2007 all the controller is, is a restriction on the vacuum line to the wastegate. makes the wastegate "see" a small amount of boost. or make is "see" no boost until you reach your desired pressure, then opens the restriction to let the wastegate open. you can keep the wastegate shut until the last possible moment, then open it. this lets you reach max boost quicker, because it isn't bleeding any exhaust off until your at max boost. thats cool thanx man. i could be totally making this up but... say u have a wastegate with no boost controller (if thats possible), will it only run on average boost? being like 7psi until u start messin with the controller? Link to comment Share on other sites More sharing options...
Hatch92 Posted November 24, 2007 Share Posted November 24, 2007 depends on what ever pressure the spring is set at Link to comment Share on other sites More sharing options...
tantrumcrx Posted November 25, 2007 Share Posted November 25, 2007 google turbo faq's read up ull be a dr in no time Link to comment Share on other sites More sharing options...
