bestvina Posted November 16, 2007 Share Posted November 16, 2007 The car was running very rough so I pulled one plug wire at a time and found the 3rd cylinder was not firing. I then swapped one of the plug wires and no difference. I put a spark tester in-line and it showed the plug was getting spark. (I had just changed the plugs the day before so I know the plugs are OK.) This civic has dual point fuel injection. Is it possible that one that one of the fuel injectors could be bad and not be feeding the 3rd cylinder? Link to comment Share on other sites More sharing options...
MP-03RSXR Posted November 27, 2007 Share Posted November 27, 2007 So you checked the spark plug and the wires going to it... did you check the distributor/cap? If not, I'd look at that before getting into the fuel delivery system. Usually if you have a problem like that, you're check engine light should be on... if it is- bring it to autozone and they'll pretty much hook up a multimeter that reads engine codes and tell you exactly what it is. Link to comment Share on other sites More sharing options...
95exd16z6 Posted November 28, 2007 Share Posted November 28, 2007 check if you got power comin from the distributor where the wire for the third cylinder goes. if your still gettin power there, then check the feul system Link to comment Share on other sites More sharing options...
Hatch92 Posted November 28, 2007 Share Posted November 28, 2007 check the pig tail on the injector and see if it is connected properly (no wires cut, or chaffed). do you have a check engine light on? Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 10, 2007 Share Posted December 10, 2007 sounds like you have a dead cylinder as you know it has spark going to that plug. It can't be the fuel as the car runs on 3 cylinders and its a dual point injection. All the cylinders get the fuel from these two injectors. one is the primary injector and the other is a secondary. Do a leak down test on that cylinder and you'll find the culprit. You can also do a vacuum test. Link to comment Share on other sites More sharing options...
