XILE777 Posted November 13, 2007 Share Posted November 13, 2007 i was messing around with the fuses (not reading the manual first) when i realized my whole audio/navi system was disabled. I've since located my PIN & was able to get the navi & stereo to turn on but there is no audio besides the XM radio. i'm getting XM to work but why is there no sound from the CD or Tuner??? Link to comment Share on other sites More sharing options...
airjordan223 Posted November 13, 2007 Share Posted November 13, 2007 not familiar with the new civics, but you have to enter a security code to get the radio working again. Link to comment Share on other sites More sharing options...
XILE777 Posted November 13, 2007 Author Share Posted November 13, 2007 i have the serial but i dont know how or where to enter it. it sounds like it may be a dealer job? sux...oh well Link to comment Share on other sites More sharing options...
airjordan223 Posted November 13, 2007 Share Posted November 13, 2007 does it ask for a code or can you turn it on and scan through the stations but just no sound? Link to comment Share on other sites More sharing options...
XILE777 Posted November 13, 2007 Author Share Posted November 13, 2007 does it ask for a code or can you turn it on and scan through the stations but just no sound? it asked for the code once & i entered it. the radio & navi turned on but there is no sound when i try to play a CD or the radio. like i said before XM seems to work fine and i've even connected my ipod to it and it sounds just fine. i just cant play CD's or listen to the radio. Link to comment Share on other sites More sharing options...
TLontheDL Posted November 13, 2007 Share Posted November 13, 2007 You are saying your radio turns on but there is no sound? Also, you stick a cd in and there is no sound? the only sound is JUST the nav?? did you ever pull out your radio and disconnect any plugs? Link to comment Share on other sites More sharing options...
XILE777 Posted November 13, 2007 Author Share Posted November 13, 2007 You are saying your radio turns on but there is no sound? Also, you stick a cd in and there is no sound? the only sound is JUST the nav?? did you ever pull out your radio and disconnect any plugs? yes. radio tuns on and navi works fine. however, no sound when i play a CD or the radio. XM radio is ok. i didn't pull out the radio or disconnect any plugs, i just deactivated the audio system when i pulled out the audio system fuse in the fuse box. from what i've read online, i think i have to re-enter a serial number. i have the radio code & serial number but do you think i'll have to take it to the dealer to re-enter the serial number? Link to comment Share on other sites More sharing options...
XILE777 Posted November 14, 2007 Author Share Posted November 14, 2007 OK so everything is fine now. i unplugged the battery for 5 minutes then re-entered the radio code and everything turned on correctly . peace! Link to comment Share on other sites More sharing options...
