95exd16z6 Posted November 12, 2007 Share Posted November 12, 2007 so when im out and about drivin my car, the engine likes to make a ratling sound that sounds like something in the bottom end is loose. it doesnt do it when im accelerating really gently, but from like 1/3 throttle and up it seems like it always makes the noise. it also doesnt start happening at a certain rpm, just whenever ythe throttle is at 1/3 way down, which i found wierd. i think it might be sumthin like a rod bearing but idk. tell me what u guys think. hopefully at some poiint im gona pull the pann and take a look at all the rods and bearings. Link to comment Share on other sites More sharing options...
ussamah Posted November 18, 2007 Share Posted November 18, 2007 so when im out and about drivin my car, the engine likes to make a ratling sound that sounds like something in the bottom end is loose. it doesnt do it when im accelerating really gently, but from like 1/3 throttle and up it seems like it always makes the noise. it also doesnt start happening at a certain rpm, just whenever ythe throttle is at 1/3 way down, which i found wierd. i think it might be sumthin like a rod bearing but idk. tell me what u guys think. hopefully at some poiint im gona pull the pann and take a look at all the rods and bearings. similar thing happened to me where i would get this rattling loudest on idle and low revs.. turned out my ac belt pulley popped off and the tensioner was just aimlessly rattling about Link to comment Share on other sites More sharing options...
Hatch92 Posted November 18, 2007 Share Posted November 18, 2007 if it was a rod bering you would know it. i just don't have an idea of what it could be. Link to comment Share on other sites More sharing options...
Humphries Posted November 19, 2007 Share Posted November 19, 2007 rod bearings yeahhhhh Link to comment Share on other sites More sharing options...
cranny Posted November 19, 2007 Share Posted November 19, 2007 DO NOT RUN THE CAR ANYMORE. it amazes me how people can hear something like that , and keep driving it. if it is rod bearing/s gone and bottom knock , your engine is done. youl need a crank , and at least one rod. Link to comment Share on other sites More sharing options...
Humphries Posted November 19, 2007 Share Posted November 19, 2007 my valves tick like a monster. then my transmission's really loud. yes, i am threadjacking. help out cranny. Link to comment Share on other sites More sharing options...
95exd16z6 Posted November 19, 2007 Author Share Posted November 19, 2007 unfortunately not driving the car isnt an option, as bad as that sounds. i have another engine that im rebuilding for the car to, so as soon as i get that one done its goin back in the car. the other thing is that idk for sure if its a top end knock, a bootom end knock, a valve tick, which is what it sounds like it could be. im not losin ne power, its just the ticking. Link to comment Share on other sites More sharing options...
cranny Posted November 20, 2007 Share Posted November 20, 2007 well , most times , once they start knocking , they dont last much longer , given the fact yours has , id say maybe its somin else. maybe , lol. just putting a new timing belt on , makes them run alot smoother man. valve adjustment. EBP , would need more details on symptoms. Link to comment Share on other sites More sharing options...
TS John Posted November 20, 2007 Share Posted November 20, 2007 Cranny, I'm gonna have to ask you about valve adjustment and all that sometime soon. Not like my engine is doing anything wrong -- it only has 42k on it -- but I want it to run like brand new... Link to comment Share on other sites More sharing options...
Humphries Posted November 21, 2007 Share Posted November 21, 2007 when i put it in gear it whines. i need a valve adjustment. i work too often to do it though. Link to comment Share on other sites More sharing options...
Tubbith Posted November 22, 2007 Share Posted November 22, 2007 Had the same problem with my b18b... only hear it when i got on it, well, with in three days it wouldnt run. Turned out to be a rod slipped a bearing. Just my input. Good luck with it staying running. Link to comment Share on other sites More sharing options...
civicswap Posted November 26, 2007 Share Posted November 26, 2007 could be o2 sensor in ur exhaust. lol Link to comment Share on other sites More sharing options...
