ericstromberg Posted November 5, 2007 Share Posted November 5, 2007 I have been having the same problem as many others with my 93 Accord 10th Anniversary. It dies intermittently, then will sometime start back up before I come to a stop without my doing anything (kinda like popping the clutch in a manual) and sometimes I have to crank it for a while before I can gt it to start. I have replaced the ignition switch as that seemed the most common issue, I pulled apart the old one and the contacts were black, but not really pitted. I have seen a number of posts regarding the Main fuel relay, but I am wondering how the vehicles dies when it is a fuel relay related problem. My car just cuts off like a switch was turned off, leading me to believe it is electrical, rather than fuel. What happens when the relay fails, does the engine sputter a little, or does it simply switch off? I am planning to replace the coil and igniter next, but will wait to hear what you guys think about the relay possibly being the culprit. I should also mention that the problem only occurs in cold weather, and especially when the engine/car is cold. Once the car has been ruinning for a while, the problem goes away. Could this be related to the distributor? Maybe a crack/condensation? Once the condensation evaps off, engine is ok? Link to comment Share on other sites More sharing options...
jschunk Posted March 4, 2008 Share Posted March 4, 2008 Its the main relay for sure, when they heat up to much or are to cold the solidered peices start to crack and dont make contact. Link to comment Share on other sites More sharing options...
