mario87 Posted November 4, 2007 Share Posted November 4, 2007 so my integra has water at bottom of the car and when i break the front carpet gets wet and i need a new carpet anyways but i would like to know why it is wet and how to get it out and stop it have any of you had the same problem?? Link to comment Share on other sites More sharing options...
Ben. Posted November 4, 2007 Share Posted November 4, 2007 Does it have a sunroof? Link to comment Share on other sites More sharing options...
Hatch92 Posted November 4, 2007 Share Posted November 4, 2007 is the floor rusted to crap? Link to comment Share on other sites More sharing options...
DC2MONSTAH Posted January 14, 2008 Share Posted January 14, 2008 is the floor rusted to crap? dude it'd be wise to check all the weather strips all around the windows and the sunroof, not to mention all the seals in an around the hatch/trunk Link to comment Share on other sites More sharing options...
90IntegraC1 Posted January 14, 2008 Share Posted January 14, 2008 my DA9 did that because the headlight seals corroded to nothing....check that and let us know Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted January 14, 2008 Share Posted January 14, 2008 Sure its water? Check if your master cylinder is bad if it gets wet when you brake. Link to comment Share on other sites More sharing options...
zimmy709 Posted January 25, 2008 Share Posted January 25, 2008 my DA9 did that because the headlight seals corroded to nothing....check that and let us know what do headlight seals have to do with anything other than water inside the headlights.. unless i just dont understand what you are sayin. anyways, i have a DC JDM carpet for sale... its black and in really good shape, if you dont mind the holes for your hatch pop and gas door pop being on the wrong side, as well as the wear patch for the driver are on the right side too. or you could rip it all up and buy my whole RHD conversion...!!! :drool: that even gets you a new master cylinder if that is your problem... or maybe its your heater core... you will get a new one of those too!!! (not trying to thread jack, just help the man out) Link to comment Share on other sites More sharing options...
speedfreek09 Posted January 25, 2008 Share Posted January 25, 2008 may be a little late in the season but if the a/c drain is clogged it could leak into the car but heater core is more likely. on my civic we use the a/c in the winter, for some reason it defoggs the window faster Link to comment Share on other sites More sharing options...
zimmy709 Posted January 26, 2008 Share Posted January 26, 2008 ^same thing here on my '92 teg... plus when i run the blower motor after it rains a lot, it leaks water from in the blower motor housing. i know its not antefreze... water is getting in the housing form somewhre... no clue where Link to comment Share on other sites More sharing options...
