greendelsol Posted November 3, 2007 Share Posted November 3, 2007 hey... i think that the pass. side window motor is dieing on me....when it goes up it goes up extra slow and sometime it stops but when i let go of the button and push it again it goes up but now even slower.... Link to comment Share on other sites More sharing options...
wannaBstuntin Posted November 3, 2007 Share Posted November 3, 2007 hey... i think that the pass. side window motor is dieing on me....when it goes up it goes up extra slow and sometime it stops but when i let go of the button and push it again it goes up but now even slower.... ok thanks for that -_- Link to comment Share on other sites More sharing options...
Hdelsol95 Posted November 4, 2007 Share Posted November 4, 2007 check the tracks on the windows and make sure the bolts arent loose, also lube the tracks up, i thought my drivers side was doing the same then i adjusted the tracks and lubed it up and works fine now Link to comment Share on other sites More sharing options...
chris_agu28 Posted November 4, 2007 Share Posted November 4, 2007 i guess i am going have to do the same thing for mine...what kind of lube did you use? like some gear oil or wd40? Link to comment Share on other sites More sharing options...
greendelsol Posted November 4, 2007 Author Share Posted November 4, 2007 +1 what kinda lube? and thanx for the input! Link to comment Share on other sites More sharing options...
Hdelsol95 Posted November 5, 2007 Share Posted November 5, 2007 silcone type lube, dont used wd40 for anything lol, or a white lithuim lube either or will work Link to comment Share on other sites More sharing options...
chris_agu28 Posted November 5, 2007 Share Posted November 5, 2007 alright sounds good! Link to comment Share on other sites More sharing options...
TS John Posted November 5, 2007 Share Posted November 5, 2007 Yeah, remember that WD40 dries really fast. It's not really a lubricant in the same sense that we're talking about here. Link to comment Share on other sites More sharing options...
JTRSOL Posted November 5, 2007 Share Posted November 5, 2007 i had the same problems with my drivers side. and all i did was spray silicone in the track of the window and it went up with no problems. so now i make it a point to every once in awhile spray both tracks. do that and you should be fine. Link to comment Share on other sites More sharing options...
Hdelsol95 Posted November 6, 2007 Share Posted November 6, 2007 Yeah, remember that WD40 dries really fast. It's not really a lubricant in the same sense that we're talking about here. +1 exactly what im talkin about Link to comment Share on other sites More sharing options...
greendelsol Posted November 6, 2007 Author Share Posted November 6, 2007 mk thanx a lot! i will do that Link to comment Share on other sites More sharing options...
chris_agu28 Posted November 6, 2007 Share Posted November 6, 2007 Thanks alot guys, i will pick up some lube for the windows today Link to comment Share on other sites More sharing options...
