del sol girl Posted November 1, 2007 Share Posted November 1, 2007 I have a 94 Honda del sol V-tec, 5speed and I need a transmission. When I look at a parts list under tranny it asks me is it a MT 1500, AT, MT 1600 SOHC or a MT 1600 DOHC. Have no idea what this means. Link to comment Share on other sites More sharing options...
airjordan223 Posted November 1, 2007 Share Posted November 1, 2007 i dont know a lot about trannies but you have a DOHC motor so im guessing its the MT 1600 DOHC. Link to comment Share on other sites More sharing options...
cranny Posted November 2, 2007 Share Posted November 2, 2007 yes indeed good sir , that would be correct. if you dont have much money del sol girl , and are just wanting a tranny that works again , lol , any 94-01 B series transmission will work for you. Link to comment Share on other sites More sharing options...
Speed_Safely Posted November 2, 2007 Share Posted November 2, 2007 MT= Manual Trans AT= Auto Trans MT 1500= D-Series 1.5 (SOHC) MT 1600= D-Series 1.6 (SOHC) MT 1600= B-Series 1.6 (DOHC) Link to comment Share on other sites More sharing options...
reewinder Posted November 3, 2007 Share Posted November 3, 2007 For the 1994 Del Sol's.... D15B7 and D16Z6 engines had the S20 transmissions. Automatics had the M24A transmissions. The VTEC models with the B16A3 engines had the Y21 transmissions. If your's is the dual overhead cam VTEC motor then you have the Y21 transmission. Link to comment Share on other sites More sharing options...
TS John Posted November 3, 2007 Share Posted November 3, 2007 What year did the VTEC model appear? I thought it was 95 but I could deffo be wrong. In that case then her 94 is just a D16Z6, in need of an s20 trans. Otherwise it's as airjordan says. Best way to tell is look at the engine code of the front of the engine block. Front middle next to your header heat shield on the left. Possibly covered in oil and other nasty stuff. Link to comment Share on other sites More sharing options...
reewinder Posted November 6, 2007 Share Posted November 6, 2007 DOHC VTEC models first arrived in '94. Link to comment Share on other sites More sharing options...
