95teg87 Posted October 31, 2007 Share Posted October 31, 2007 Whats up guys my name is James im new to this forum I have a few questions about a engine swap I have a 1995 Acura Integra 1.8L LS non vtec (automatic tranny) I want to swap it out for a 1995-1997 G-SR VTEC and switch from an auto to a manual tranny now i'll be doing all the work myself so i need as much advice as I can possibly get, and here are the questions: Should everything basically mock up to the new engine i just have the G-SR head? Do I need to get motor mounts for the new engine during the swap? How hard and how long does it usually take to convert a auto to a manual with a auto tranny setup in the car ( if i have all the nessecary holes drilled and pedal kit)? Is there anything else I might need for the engine swap? Any and all comments, advice and tech tips will be gladly appreciated!!!! Link to comment Share on other sites More sharing options...
TS John Posted October 31, 2007 Share Posted October 31, 2007 I'm assuming that you have a donor car for this of the same generation, or else this will be a major headache tracking down individual parts. It will be a lot of work. Someone on here just recently swapped from auto to manual in his teg and it was a lot of work. Search around for threads made by 90IntegraC1. The engine swap should be fairly straightforward as engine swaps go, especially if you have a complete donor car. Good luck. Link to comment Share on other sites More sharing options...
