96 Civic Posted October 30, 2007 Share Posted October 30, 2007 I have a 1996 honda Civic. I notice that when I drive between 75-80 mph my stering wheel vibrates. I replaced the tires but the problems was still there. balance the tires about 5 times and the vibration still there, I had a local tire shop check my hardware and everything according to them is fine, later they found 2 defected wheels, which I have replaced all with new ones. but the problems still seems to be there. any advice? Link to comment Share on other sites More sharing options...
Kegger Posted October 30, 2007 Share Posted October 30, 2007 You need an alignment. Link to comment Share on other sites More sharing options...
96 Civic Posted October 30, 2007 Author Share Posted October 30, 2007 sorry I forgot to mention that, I had an alignment done when I purchase the new tires. Link to comment Share on other sites More sharing options...
Kegger Posted October 30, 2007 Share Posted October 30, 2007 Make sure you haven't blown any CV boots. But I'm pretty sure your alignment sucked. Link to comment Share on other sites More sharing options...
adamEj6 Posted October 30, 2007 Share Posted October 30, 2007 maybe new rotors? Link to comment Share on other sites More sharing options...
airjordan223 Posted October 30, 2007 Share Posted October 30, 2007 maybe new rotors? that would only be if it got worse/started when you were braking Link to comment Share on other sites More sharing options...
wannaBstuntin Posted October 30, 2007 Share Posted October 30, 2007 definitely alignment or wheel balancing....get someone better to do it...not WalMart Link to comment Share on other sites More sharing options...
Hdelsol95 Posted October 30, 2007 Share Posted October 30, 2007 its probley ur wheel bearings Link to comment Share on other sites More sharing options...
Rone811 Posted November 5, 2007 Share Posted November 5, 2007 Im having the same problem :( i posted like 5 min ago thought i would find an answer here ....the depression continues :*( Link to comment Share on other sites More sharing options...
TheJGB3 Posted February 6, 2008 Share Posted February 6, 2008 The cars alignment WILL NOT CAUSE a vibration - Unless your wheel alignment is WAY out of spec...I mean you can obviously see that the wheels are WAY crooked when you look at the car. Link to comment Share on other sites More sharing options...
Kegger Posted February 6, 2008 Share Posted February 6, 2008 Dude, WTF? Alignment does not have to be out noticeably to cause an impact. If your toe is out it can cause an evil vibration. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted February 6, 2008 Share Posted February 6, 2008 Holy old thread, batman! Link to comment Share on other sites More sharing options...
FreshDaily Posted February 8, 2008 Share Posted February 8, 2008 did you check the tie rods?? lowerball joints?? I had a similar problem occur with a 96 Camry, and it turned out to be the lower ball joints...You couldnt tell they were bad when mounted to the car and like put a hand at 12 oclock and 6 o clock and try to move the wheel. But soon as I disassembled them off the control armm, I could pop them in and out easily!...At normal speeds like 20-50 mph there was no shaking, soon as you hit the highway the shaking appeared!....just an idea!..... Link to comment Share on other sites More sharing options...
Hatch92 Posted February 8, 2008 Share Posted February 8, 2008 this thread was dead and TheJGB3 brought it back from the dead. Link to comment Share on other sites More sharing options...
